Question about Canon IXUS V2 Digital Camera
Ixus 70 lens error - lens wont open - Canon IXUS V2 Digital Camera
When i turn on my cannon 1xus70 camara lens error comes up on screen then turns of any answers please
Posted on Sep 29, 2008
With the camera function set to veiw photos not to shoot, hold down the start button and the timer/ delete button at the same time....keep them held down. This worked for me wile I was on the phone to Canon- it was news to them!
Posted on Jan 26, 2009
Try On/off Disp. and Menu all together, it worked for me
Posted on Feb 08, 2009
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Error on lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 18, 2009
parjee
  • 83 Answers
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Posted on Sep 22, 2009
  • 11967 Answers
SOURCE: ixus 70 lens jammed open says lens error restart
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 20, 2009
Hi, I have a Canon Ixus 70. Had it for several years. Suddenly the lens protection does not open when I start the camera, or opens only half. This is no lens error. The lens is behaiving normaly and...
hi! there is something wrong with your camera lens or the parts around the lens like the bayonet or flex cable. so it is better replace them or send to some professionally maintance center such as www.skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
Aug 17, 2011 | Canon IXUS V2 Digital Camera
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to fix digital camera canon ixus 70 'lens error restart camera'?
Sep 02, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Error on lens
Jan 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart Camera
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera lens will not open
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Lens error
Press the power button on and hold it down while extending and twisting the zoom lens......
Oct 03, 2008 | Canon IXUS V2 Digital Camera
RE: Canon solution
It is most probably that your hand was in the way when the lens is trying to come out.
Try restarting and make sure no obstructions are in the way of the lens.
Sep 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon IXUS V2 Digital Camera Logo
253 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
