Water is not filling bucket but is staying in the top of the unit and leaking out
    Brigadier General:
  • 4,736 Answers
Birdy, I don't think the water you're seeing is from what the dehumidifier has collected. It sounds like the dehumidifier is frozen up. In which case, turn the Master ON/OFF Switch to OFF and unplug the unit, to allow it to thaw for several hours. You may want to put some old towels under it while it thaws.
Once the unit has completely thawed, remove the air intake filter and clean it. Do not reinstall it, until it is completely dry. Also, wipe off any remaining moisture that you see on or under the unit.
Once everything is thawed, cleaned and dried, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity level at 35 to 45% and allow the unit operate as it should. Always remember, there must be at least 2 feet of clear air space around the dehumidifier for it to function properly.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 24, 2011
Why would the system keep running, all the time, filling up bucket, then leaking onto floor? What is my next step?
There is supposed to be an auto-shutoff float in the bucket to prevent overfilling of the bucket. You have either removed it or it is defective. The fact that it runs constantly has more to do with the humidity and the setting that you have the unit set to, Obviously there is adequate humidity in the space or the bucket would not fill. You need to look for, find, and repair the shut-off float, or, if possible, some units allow you to connect a drain hose either to the bucket or directly to the unit to drain the water to a drain. If you choose this option, remember that the hose must remain lower than the top of the bucket or it will not drain properly and the bucket will still overflow.
Jan 23, 2016 | Dehumidifiers
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
What would cause my ice maker to leak into the plastic ice bucket?
The most likely cause is the fill valve is leaking and causing the ice maker to overfill. Try a new fill valve. Usually located on the rear of the appliance. (where you hook the water line to).
May 02, 2014 | Whirlpool GZ25FSRXYY
It runs but leaks water, water won't stay in bucket
Denise, there are several things that can cause the problem.
1. The water collection bucket is not installed properly. Turn the unit OFF and remove the bucket. While you have it out, look at the top of the bucket, is there a float valve near the top. If so, it may be stuck in the DOWN position, which tells the dehumidifier the bucket is not full yet. Jiggle the arm of the float valve to see if it moves freely. Reinstall the bucket bucket "squarely" from top to bottom into it's holder. The bottom should not tilt down at all, if installed properly.
2. The drain tube to the bucket may be clogged. To solve this problem do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
3. The water you're seeing may not be from the bucket overflowing or leaking. It's condensation that is has built up on the cooling coils and is dripping down under the unit. If this is the case, it's an indication that the coils are dirty and need to be cleaned. Warm water and dish washing liquid works well to clean the coils. Be sure to rinse them with a damp rag, dry thoroughly and spray a light coating of WD40 on them.
I hope that all the information I have provided will help you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | Goldstar DH504EL Dehumidifier
All of the water came gushing out onto the floor...all hoses attached and in good shape
Nine tine out of ten the fill valve housing is cracked, try filling washer with bucket if no leaks that will prove it, if leaks with bucket fill the problen is probably the water pump or hose's that go to it
May 15, 2010 | Frigidaire FWSB5700DS Top Load Washer
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Overflow
You should be able to connect the unit to a drain hose - then you won't have to empty the bucket. Have you tried that?
Otherwise, you only have 2 options I can think of:
1) empty the bucket frequently (before it fills up) or
2) siphon off a bit of the water before jarring the bucket
BTW, I eventually gave up on using dehumidifiers unless I was trying to dry out wet carpet. They are a hassel, and they are essentially A/C units that doesn't give you cool air.
Aug 08, 2008 | LG LD50EL Dehumidifier
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
