Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Hello My pc will not power up, the on button at
Hello My pc will not power up, the on button at the front of the tower is flashing amber/yellow. When I looked into the back of the tower there is a red flashing light. Any idea's? the fan doesn't come on and nothing displays at all on the monitor. I think I have the correct PC below from the picture but I am not at the PC at the moment I am at work. Thanks in advance
    Sergeant:
    Champion:
  • 357 Answers
You will need to replace the power supply which you can buy from a local computer repair shop or Dell, just make sure it is the correct model for your PC.
The cost should be around $35 for the part and it is not too hard to install, just make sure you connect the connectors correctly.
I hope this helps.
Good luck and have a pleasent day.
Posted on May 24, 2011
I have a Dell Dimension 5150 desk top computer which I have moved to another room & now won't switch on, just flashes an Amber light to the front of the hard drive. Is this something I can fix...
A flashing amber power LED indicates that the power supply is not providing the correct voltage.
  1. make sure if there is a voltage switch on the power supply that it is set to the voltage of your country (120 VAC for North America) maybe cycle the switch from 120 to 240 and back
  2. If the switch is set right and you are using a power strip/battery backup, by pass it and plug directly to the wall.
  3. Make sure the black and yellow 4 pin connector for the processor is connected on the motherboard.
  4. if all the above have no effect, replace the power supply in the tower
Sep 02, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
MY DELL IS OPTIPLEX 760SFF, IT NOT BOOTING, SHOWING AMBER LIGHT ON THE POWER BUTTON WHEN PLUG TO POWER.
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Proton
Aug 10, 2010 | Computers & Internet
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165004
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Don't starts yellow light flasing
If the power button on the tower is flashing Amber, the fault is the power supply. Replace the power supply and they system should work.
If the power supply doesn't resolve then the 2nd most likely failure is the Front IO panel (Circuit card behind the power button)
Nov 22, 2009 | Dell XPS 400 PC Desktop
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Yellow lite flashing on dell demenison, will not turn green!Clean tower and it work for a wile but it goes back to yellow or amber
I think that either there is a faulty connection on your power supply or the power supply itself is faulty and needs replacing. Good luck.
Oct 01, 2008 | Computers & Internet
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
