Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
We have a Frigidaire front loading washer model#FWT645RHSO, and need to know what size screws go in the lid to keep in fastened to the back of the washer
  • 641 Answers
SOURCE: Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Posted on Sep 08, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
TampaNative
  • 778 Answers
SOURCE: My FWT645RHSO front load washer
Hello Twisted1,
If you have adjusted the level to reset and then to where you want it and it still won't fill to the level you want, I would suspect the level sensor in the washer itself. Most washers have to be switched to reset before setting a lower or higher water level. I hope it's as simple as the reset level switch for you.
Good Luck.
Posted on Feb 28, 2008
  • 105 Answers
SOURCE: Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
Posted on Mar 16, 2008
What is the drum size of the washer?
Hello Friend, that's a great question!
In order to provide you the correct drum size of your Frigidaire washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front as you open the door if you have a front load washer. If you own a top load washer, you may find the serial tag inside the lid, on the right side. Thank you and I look forward to your response.
Jul 24, 2014 | Frigidaire FWSB5700DS Top Load Washer
Where do you find the model # for a frigidaire washer? The tag under the lid has been removed.
Hello saguilar891 - Generally speaking, the model and serial numbers on Frigidaire front load washers are located on the upper front, as you open the door.
Nov 12, 2012 | Frigidaire GLTF2940ES Front Load Washer
Top load washer - won't spin - how so i get the back off to check the belt?
If this is a frigidaire.there are two clips about one inch in from either side of the machine in the front that you need to push in with a flat tip screw driver to loosen the lid.then there are two screws down on the bottom front that need to come off,then the front panel will come off to access the belt
Sep 13, 2011 | Frigidaire GLWS1349A Top Load Washer
My Frigidaire front loading washer drains completely when the cycle is done, but then fresh water slowly accumulates over time in the bottom of the tumbler (maybe 4 inches). What can I do about this?...
Hi, Your problem lies with the water valve needing to be replaced. It's where the two hoses fasten on in the back. Unplug machine take the top off and you'll be able to get to it. You'll need your full model number to get the part at your local parts house. Hope this helps.
Jan 17, 2011 | Frigidaire FTF2140ES King Size Front-Load...
How to take off the front panel?
hI.. yOU NEED TOTAKE OUT THE SOAP DRAWER.... UNDO THE SCREWS HOLDING THE FRONT PANEL ON... TAKE THE LID OFF... UNDO THE TWO SCREWS ON TOP O THE FRONT PANEL.. UNDO THE DOOR RUBBER AND FOLD IN MACHINE... UNSCREW DOOR INTERLOCK.. AND REMOVE NOTING TERMINAL CONNECTIONS... UNSCREW THE TWO SCREWS AT BOTTOM OF PANEL, AND HEY PRESTO... IT IS OFF....!!!
BEFORE YOU START MAKE SURE THE APPLIANCE IS SWITCHED OFF AND UNPLUGGED - THIS IS VERY IMPORTANT..
Mar 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
During wash cycle the tub doesn't lock.
Lid lock may be damaged. Unplug, remove the front by the bottom 2 screws. Look at lid lock to see if it has overheated or damaged. Let me know, Thanks, Sea Breeze
Mar 10, 2009 | Frigidaire GLWS1233A Top Load Washer
Whirlpool "Roper" top-loading washer leaking
two screws hold back control panel on. panel flips up. two clips hold case on. remove clips and lid switch plug and whole outer case will tilt forward off machine base. pump is down in front and can be bought separate.
Apr 14, 2017 | Roper RAX4233PQ Top Load Washer
E90 alarm code keeps coming up on zanussi washer
E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
remove 2 screws at the back which secure the top,
push the top backwards,
unplug the connectors to the front panel,
vibrations due to unbalanced load may have loosened them,
push them firmly back in socket,
pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
power on,
run the machine empty for minimum cycle - rinse only.
Good luck!!!!
Aug 18, 2008 | Washing Machines
if that is clear
Mar 15, 2008 | Frigidaire ATF6000ES Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
