Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Forgot to drain the gas last fall and found it had small amount of water in the tank. Drained it out and cleaned the fuel filter, cleaned the carb out and now it starts, but runs only if the choke is on.
    Problem Solver:
  • 17 Answers
I would recommend replacing the fuel filter and spark plug. If this is a 2-cycle engine be sure you are using fresh gas with the proper oil mixture. If your engine has a fuel primer bulb be sure to push it several times until you feel resistance before starting and make sure there are no fuel leaks. Failing that you may need to adjust the carb fuel mixture screws after the engine runs long enough to warm up (1-2 minutes). Check your owners manual for other troubleshooting procedures. Good luck.
Posted on May 24, 2011
Scag Turf Tiger. Why does it keep stopping like it's out of gas?
Did you clean the fuel bowl on the carb as well the fuel jet could be dirty as well. Sounds like a dirty carb or does it have a fuel filter that is dirty. If you have a fuel bowl on the carb I suspect that could be the problem. When you clean it make sure you clean the fuel jet.
Jun 09, 2015 | Garden
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
1987 mercrusier 180hp wont stay running unless i pump the gas
Could be a small amount of rust got into fuel filter from sitting empty, try changing fuel filter before worrying about the fuel pump.Filters could be partly plugged and its always smart to start with the cheaper fixes first.
Apr 14, 2012 | Cars & Trucks
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
HINO NO4C MOTOR STALLING ,HAS NO DTC CODES ,ENGINE STARTS FOR ABOUT 10 SECONDS THEN SHUTS DOWN !Fuel filter replaced,found small amount of metalic in bottom of bowl!Air filter ok and no leaks,some times ok...
sounds like a fuel tank inspection/flush or replacement is on the horizon.... sometimes dirty fuel has contaminated your tank or the tank itself is rusting from the inside out... either way it needs to be addressed... drain the tank analyse what gets drained for particles and water...send the tank to a radiator shop for a complete boil out/inspection....blow out the lines and replace the filter again along with the fuel bowl etc. after that all should be well?
May 06, 2010 | Toyota Land Cruiser Cars & Trucks
What to do found water in gas tank of pressure
have you drained the tank, and disconnected the fuel lines from the carb. so that the carb will drain? if not you need to get the water out of the carb. the put some rubbing alcohol in the new gas and this should get rid of any residual H2O
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
I may have put water in the gas tank what should I do? i used two bottles of water evaporator already and it still wont start. Do I need to do major work now?
you will have to try and drain it out, if there is no drain plug, remove fuel tank, water evaporator will only deal with small amounts of moisture, you will also need a new fuel filter and drain the carb(unless it is injected) and the water can corrode the injectors after time
Apr 05, 2010 | 1997 Chevrolet Blazer
I picked up some dirty fuel
Water condensation inside the tank is where the water probably came from. Consider a liquid tank liner to seal the rust from the gas and prevent further rusting. Google “ kreem liquid fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
Drain the carbs. If that doesn't work check the plugs for feathering. If that doesn't fix it then remove the float bowls and clean the carbs.
Aug 06, 2009 | 1996 Suzuki GSX 600 F (Katana)
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
Chevy s-10 pickup truck water in gas 6 cyclinder
check basics ...air /fuel /spark...try spraying carb cleaner into throat of throttle body to see if it starts and runs on that ...advise us/me
Nov 10, 2008 | 1997 Chevrolet S-10 Pickup
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
179 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
