Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Valve clearance on 6.5 intec lawnmower eng. briggs&straton
3 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: 7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Posted on Jul 12, 2010
  • 12 Answers
SOURCE: Everytime I try 2 start the engine (pulling the
black smoke normally indicates exess fuel, try cleaning the air filter and replace the spark plug
Posted on Aug 05, 2011
124t02 Briggs and Stratton lawnmower valve clearance
.004 and .006 , just set them both at .005 and it will run like new
Mar 11, 2018 | Briggs Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
I have a briggs &straton intek 26 hp and the compresion seems to be not releasing.what can i do?
If the valves are adjusted too loose, the compression release will not work, and will make starting the engine difficult. I believe the clearance is supposed to be .005". If the clearance is too large, the 'bump' on the cam will not move the valve off its seat when cranked slowly, and compression will make the engine hard to crank over.
Jun 18, 2012 | Measuring Tools & Sensors
Briggs and straton 5 horsepower overhead valve lawnmower 1978 is backfiring through carborator
Remove the top engine cover and check that the aluminum flywheel key is not sheared, then remove the valve cover and ADJUST the 2 overhead valves. They have to be adjusted periodically on ALL small engines with overhead valves.
Aug 13, 2011 | Garden
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
111 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
