Question about Tally Office Equipment & Supplies
Tally T2265 check ribbon error wont clear - Tally Office Equipment & Supplies
  • mondalprabir Sep 26, 2008
    showing check ribbon
  • dino0511 Nov 12, 2008
    I received this error when putting in a new ribbon cartridge. I tried to power off, reinstall cartridge, check the cartridge holder for any sensors or damage, but nothing clears the error.
4 Suggested Answers
SOURCE: please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Posted on Nov 24, 2008
SOURCE: "check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
  • 169 Answers
SOURCE: tally t2265 'check ribbon' hardware alarm...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Posted on Aug 24, 2009
Testimonial: "Really good advice, checking those ribbon part numbers can save a lot of wasted time stripping the printer down! Not a very nice machine to work on! m"
SOURCE: Hi There. I have Tally
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Posted on Mar 10, 2011
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
2265+ ribbon error
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
Instruction manual will explain better
http://www.softwaredriverdownload.com/download.php?file=964rxfbkkrZnRwOi8vZnRwLnRhbGx5Z2VuaWNvbS5jb20vcHViL2dlbmljb20vZG9jcy90YWxseS9zZXJpYWwvdDIyODAvMDYzMDUwYV9vbTIyNjVfZ2IucGRm
Dec 27, 2008 | Tally T2265 Dot Matrix Printer 917402
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Dec 01, 2008 | TallyGenicom (048959) for T2265, T2280,...
Please help
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
516 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
