Question about Sony Ericsson T715 Cell Phone
Charger does not make good connection,i have three different charges and all are the same
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
Hi, Since you have tried up to three chargers,and still no solution,that means the problemis not from the charger it self..
You will have to look at the charging port of the phone to know if it's well placed.Might be shaking and making it to loss contact with the charger..
You can unscrew the cell phone to see how firm the charging port is. And if not firm,that means it's failing..
You will need to get it fixed.It can be replaced.
Take care..
Posted on May 24, 2011
Will not accept AC power
Try to charge it with different Apple charger. If your PC is under warrenty then you could call Apple Costomer Service and have them send you a new charger. The number is 1-800-676-2775.
Jul 07, 2010 | Apple 13" MacBook Notebook Computer ...
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
Makita dc24sa charging problems
most likely your inverter is going bad,,,time for a new charger
Nov 30, 2009 | Makita DC24SA 24 Volt Makstar Battery...
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
Pin in charge hole got loose then disappeared
Unfortunately this is a common problem, it can be repaired but unless you are an electronics technician I suggest you take it to the service provider if it's still under warranty. If not there will probably be a small fee. It may not be worth the cost to repair it so you may just want to replace the unit. Good luck
Oct 16, 2009 | Palm Zire 72 Handheld
SYMBOL 3140 WON'T CHARGE THE BATTERY
try buying a new charger the charger might be bad
Jan 06, 2009 | Symbol PDT 3100, 3140, 3142, 3146...
Phone will not charge
try once using original charger and just check that your charge pin is connected well with the phone
Mar 12, 2008 | Motorola Mobility V365 Cellular Phone
Sony Ericsson T715 Cell Phone Logo
278 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
