Question about Canon Office Equipment & Supplies
I have no idea where a part goes in my copier. When I got the copier this part was loose.
Where was this part when you found it?
Posted on Aug 16, 2008
I have a Toshiba 1360 copier. Went to use it
sounds like one of the charge corona wires broken or the hvt board blown
Jun 11, 2010 | Toshiba Office Equipment & Supplies
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
I keep getting a little blue screen pop up that asks me to select input, d-sub or dvi. I select either then hit enter on my monitor but it keeps popping up. Any ideas how i can fix this.
you probably got a loose connection inside you monitor or your cable is loose, check both ends
1. check the end that goes to the video card
2. chec kthe end that goes into the monitor
3. if that does not shore it up it maybe a short inside so you may want to check that.
thanks
Jul 16, 2009 | BenQ T904 19" LCD Monitor
I have a Panasonic DP 2310, everything starts and goes to ready. I press start and the display blinks, almost like a power recycle and it says copying but nothing happens, no errors. Any ideas?
there is a short on the board under the start button some where , its quite possible that the solder on the button has come loose and you mite need to solder it again
Jun 29, 2009 | Panasonic FP-D605S2 Copier
Only prints once ?? Toshiba BD-3810
When the toner is very low the copier is programmed to only print one copy.
Fill the toner and it should go back to normal
Dec 05, 2008 | Office Equipment & Supplies
Charger cable green light on but when placed in back of laptop nothing happening no lights on computer to show recharging.......where the cable goes into back of laptop its very loose is there ...
where the cable goes into back of laptop its very loose that needs to be fixed soldered or there might be a screw that needs to be tightened I had the same problem with my laptop.
Nov 02, 2008 | Acer Computers & Internet
95 Buick LeSabre goes dead while I'm driving
hmm. . . had te same problem before. . . and those kinds f problems **** cuz they dont stay broken long enuf to trouble shoot. . . leme see. . is can be a loose conection in your ignition system. faulty plug wires. . . in my case it was a loose wire stuck to the ecu , . no idea how it got loose but it did. . and another time the wire going to the fuel pump got loose. . . good luck troubleshooting
Oct 22, 2008 | 1995 Buick LeSabre
Lexmark x2690
make sue the cartridge is installed and not loose
Jun 30, 2008 | Office Equipment & Supplies
18 people viewed this question
old marine
old marine
