HP LaserJet 1102 Printer could not mirror printing
vijay
  • 27 Answers
SOURCE: HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Posted on Mar 12, 2007
EPIJAB
  • 89 Answers
SOURCE: HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Posted on Jan 22, 2008
jaylex
  • 417 Answers
SOURCE: My HP LaserJet 6L Won't Print on new HP/Vista PC
Hi there I think that vista has a problem with IEEE 1284 connections try setting the driver properties to no bi directional printing. If not then I suggest to get a HP jetdirect box so you can use the Cat5e network cable.
Thanks J
Posted on Jan 28, 2008
  • 138 Answers
SOURCE: HP Color LaserJet 2600n Printing Problem!
franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Posted on Sep 03, 2008
  • 102 Answers
SOURCE: Is it possible to take mirror image printing using by HP Laserjet 1022
That works as the Driver and application( End user is using) settings.
This can be done from software not hardware.
Posted on Jul 04, 2009
How can i print a mirror image on an HP laserjet 2840
On your computer you go into control panel then printers, right click on your printer and select properties. Select printing preferences and go thru the tabs and you'll find mirror image and select it by clicking in the box or circle. Remember to go back and turn it off or all will print in mirror.
Jan 29, 2010 | HP LaserJet 2840 All-In-One Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Jun 01, 2009 | HP LaserJet 1020 Printer
Printer hp laserjet p2015n
laser unit mirror is dirty clean it than solve it
May 29, 2009 | HP LaserJet P2015dn Printer
Magenta won't print
It's normally caused by dirty scanner mirrors, the machine will need to be dissembled, the laser scanner unit removed, taken apart and the mirrors cleaned. Unfortunately it is quite fiddly getting the scanner unit out, but this is a very common problem for the HP colour laserjet 2600's
Aug 24, 2008 | HP Color LaserJet 2600n Printer
HP OFFICEJET PRO L7780 ALL-IN-ONE
sure...it's in the printer settings..there's a check box for mirror or reverse printing..make sure it's unchecked
Aug 20, 2008 | HP LaserJet 2605DTN Color Printer
Hp color laserjet 2600 megnta not printing
thanks alot u solutions.iam very happy for giving me this knowledge.faisal
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Prints really light on left side of paper
You might need to replace the fuser. You can purchase the mainteance and fuser kit from HP or other like ompanies.
Nov 22, 2007 | HP LaserJet 5100tn Printer
k24674
jasbo
jasbo
