Question about Husqvarna Huskystar 215 Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's called that houses the bobbin and brushed out lint & dust. Now I can't make the bobbin housing sit flat enough that I can put the metal plate back in place over the teeth.
  • 1,238 Answers
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on May 25, 2011
  • bonifacio gomez
    bonifacio gomez May 25, 2011
    please don't forget to rate my answer
Machine Locked
Hi, First of all, make certain you remove both parts of the needle. Sometimes it breaks under the plate and knots up with the bobbin. If that is so, lift the presser foot and carefully try to lift the plate so you can get scissors under it to cut the thread and free the needle. Pull the bobbin out and replace it and put a new needle in. It should work fine.
Feb 04, 2014 | Consew 7360R-1 Mechanical Sewing Machine
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
How do I change the cutting blade in my Designer 1 Embroidery Machine?
You need to remove the gray cover next to the needle plate and bobbin cover. First remove the bobbin cover, needle plate, hook cover, and bobbin case. Next, take a small straight slot screw driver, about 3mm wide, and insert it under the gray cover that is just left of the hook area. Pry up the cover just slightly, and at the same time slide the cover towards you. It should just pop off. If you having cutting problems, you should the cutter blade, the cutter holder (black plastic piece), the fetcher (gray metal arm), and the thread bread (copper piece with the little velcro piece at the end). Viking has upgraded a couple of these pieces from the original versions, so you should have better cutting results. And of course clean out this area while your at it.
Apr 28, 2011 | Husqvarna Designer I
Just started to tangle up and jam up not letting needle to go down making a metal noise followed by jaming noise
Sounds very like a bent needle or jammed bobbin case. have you cleared any broken threads or replaced needle? Lift the needle plate and check under that too.
Nov 26, 2010 | Brother CE5000 Computerized Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Bobbin trouble
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
May 01, 2010 | PfaFF Hobby 4260
The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Nov 04, 2009 | Husqvarna Designer I
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Singer Simple 3116
Your problem is a simple one.Jamming is due to thread getting trapped on the bobbin holder.All you need to do is to unscrew two screws holding the the bobbin holder clean the same and reasseble it.your problem will be solved.N.Govindarajan
Jun 09, 2008 | Singer 3116 Simple
Husqvarna Huskystar 215 Sewing Machine Logo
337 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
