Question about Toshiba Satellite M45-S165 Notebook
My computer will not start. Where is the battery?
    Sergeant:
  • 167 Answers
Are you looking for the battery or the battery is not working even the charger is connected
Posted on May 24, 2011
Computer just shut off and wont come back on. what can i do?
your battery power plan is not set correctly.
you have a bad battery
unplug unit. Take out battery pack plug unit into power without the battery installed.
if it starts up go to control Panel and reset power plan. have alarm go off at 20%
shut computer down... install battery pack...Start the computer
you should see battery icon and it should indicate it is plugged in and charging. if it doesn't start up you may have bad battery
Nov 27, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Im trying to open my DELL vostro 200 desktop but it wont turn on. Hope you can help me to fix it. thanks!
you may not like the answer
unit may been dropped
suggest you remove battery and start unit without battery installed.
don't worry if it starts up goto e-bay and price a new battery.. I said price not bid or buy..get info off battery...shut down computer pull power plug...install old battery...install power plug...start computer.
if computer starts up... good. everything is great.
if not determine if battery is bad,,, best test is a load test....next best test....borrow a similar battery from a known working computer,,, if the computer starts up goto ebay and bid on a battery.
Nov 25, 2010 | Computers & Internet
My laptop is not starting when I plug in adopter the charging light shows but when I press start button light goes off and it does not start. Is this a battery problem. I always use the charger/adopter to...
Try removing the battery and then starting the computer with the power cord. Sometimes the battery is bad and prevents the computer from working properly.
Aug 02, 2017 | Acer Ferrari 3200 Notebook
I am having trouble starting my computer. As soon as I press the power button, the battry indicator lights up, but the computer does not start. I have tried taking out the battery twice, and still, my...
Is your AC adapter working correctly?
If it is, then removing the battery should allow the computer to use the AC line to power the computer.
If it is not, then your battery is drained, and needs to be recharged.
Nov 05, 2009 | Acer Aspire One PC Notebook
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
Toshiba laptop won't start
pls replace the ac adapter and charge the battery, after fully charge pls check the power on. if not pls power without battery, also remove the battery and power on , after power off plug the battery,
Sep 28, 2017 | Toshiba ZA2055P08 - Satellite 1800 24X...
Start up
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Aug 03, 2008 | Computers & Internet
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
Medion Akoya EX Laptop computer
It sounds to me like some of the cells in the battery has collapsed.
A 12 volt light doesn't use as much juice on the battery as when you boot up. When Mobo, Monitor, Harddrive etc etc. start up they all use a large start-up-current and if the battery cant sustain the amount of amp. they all need together, nothing happens.
This is called shadow-charge, the battery seems fine, but when it really needs to put out some power it collapses.
I think you should try to sniff up another battery and see if this one has the same problem.
Or perhaps investigate wether or not you still have some warranty left on the battery, to try to get a free replacement.
Oct 11, 2007 | Medion (40010998)
Toshiba Satellite M45-S165 Notebook Logo
12 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
