Question about GE JKP45 Electric Double Oven
Bottom oven will not heat. stays at 100 when I turn it on.
  • 2 more comments
  • Richard DeWire May 24, 2011
    There has been no repair on this oven to have reversed the wires and bottom oven worked fine for 12 years up to this point. When I turn the bottom oven on to heat, it stays at 100 degrees and does not heat at all. The top oven seems to work fine.
    I replied to you about 2 hours ago. Any more suggestions?
  • Richard DeWire May 27, 2011
    Can I reset this thermostat myself or do I need to purchase a new one? I believe I've have found it behind the grill. Does it have two wires attached and attached to the blower encasement with 2 screws? Thanks
  • Richard DeWire Jun 02, 2011
    I'll likely have some one come in an look at the oven. I think there are so many possible things it could be that I don't want to replace sveral parts before I find the problem. thanks
  • 17,970 Answers
The solution applies to most built in GE ovens, but the wire coloring may be different for some models. Make sure you check your wiring diagram that is specific to your model number.
Symptom: F2 errors, oven display stays at 100 degrees, uneven cooking.
Description: You turn on the upper oven and set the temperature. The left orange numbers on the display light up and show the set temperature. After about a minute the left temperature shows 100 degrees and stays there. You check the upper oven, but it is not getting hot. The lower oven starts to warm up. If you set the lower oven, the exact opposite scenario exists.
Cause: When the upper oven is set, the control board turns on power to the elements and measures the temperature in the upper oven. The problem is that if the orange wire is connected to DLB2 instead of DLB1 and the yellow is connected to BA2 instead of BA1, the lower oven will begin to heat instead of the upper oven. In short, the wiring is wrong and needs to match the wiring diagram. Here is an example that covers most built-in GE ovens:
Upper Bake(BA1) - Yellow Lower Bake(BA2) - Yellow/White
Upper Broil(BR1) - Violet Lower Broil(BR2) - Violet/White
Upper DLB(DLB1) - Orange Lower DLB(DLB2) - Orange/White
This page ( fixyourboard.com/boards/WB27K5119 ) describes a common hook up problem that fortunately is easy to correct and causes no permanent damage. A partial list of model series that this applies to is: JKP44GT JKP44GV JKP45WP JKP45WT JKP45WV JKP54GP...
Hope helps.
Posted on May 24, 2011
  • GE Master
  • 2,605 Answers
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, I haven't seen anywhere in the post dialog where this has been mentioned or that you've checked it though, have you checked ?
I should also verify you have confirmed the lower element is getting 240vac and there is no wire breakage as that too can manifest in the manner you described.
As for the hi-limit safety, unfortunately it is the non-reset type hi-limit on these ovens, though it may sub to the reset-able type when a replacement is purchased ( if the oven is indeed a JKP45 model ) It is shown here and is behind the grill between the two ovens...
being that it is located between the two ovens behind the grill where the lock is for the lower oven, so it is a challenge to get to, but the part is available at "repairclinic.com" or "searspartsdirect.com" on-line parts vendor for approx. $10-20USD. but if you jump it out to test it and then replace it, you can get the oven back up and cooking.
** Please turn off the breaker before attempting any service please...safety first **
Let me know how you make out or if indeed you've already checked the hi-limit thermostat. I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Posted on May 25, 2011
  • Mark MacDonald
    Mark MacDonald May 27, 2011
    Hello again,
    Thank you for replying, to answer your first question, you will likely need to replace it. The model number I looked up based on your post indicates it is a single throw, not resettable unfortunately.
    To address the second part of your post, " Does it have two wires attached and attached to the blower encasement with 2 screws " yes that should be it, though it is a nuisance to get to and on yours there may be two...one for the fan and one for the hi-limit safety.
    Let me know if I can help you going forward. The replacement number sometimes substitutes to the reset type and is original # WB24K5085 and # WB24K5049, but double check with your parts provider of choice. Good luck.
    Regards,
    Macmarkus :)
GE JKP26Gop2bg
If the oven is 23 years old, it could be time to replace it.
May 20, 2017 | GE Ovens
The bottom oven in is not heating.
I would call the service repairman , probably had a element go bad
Jan 06, 2016 | Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Not heating stays at 100
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 17, 2010 | GE JGRS14 Gas Single Oven
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
Oven not Working or Oven not Heating
heatman101
Oct 13, 2010 | Maytag Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
GE JKP45 Electric Double Oven Logo
530 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
