1993 Dodge Dakota Logo
Posted on May 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heating core - 1993 Dodge Dakota
Anonymous
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on May 24, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
94662
Points
870
You have to be more precise in your questioning so we can add a solution just saying heating core is vague and we can not read your head or brain so please explain what is happening in steps here so we can know what might be your problem thanks.
Heater problems 2009 dodge nitro v6.
Possible, with rad cap off, let vehicle idle until coolant fan comes on then shut vehicle off for 30 minute cool down. Top up rad, install cap and drive and recheck heater operation and any overheating.
2answers
2001 Taurus No Heat
heat control valvue could be stuck closed not allowing water to pass through the heater core
I changed the heating core but now my windows are fogging up when i turn on my heat and i also smell antifreeze coming thru the vents what seems to be my problem???
heating core has been plumbed in wrong or most likely has a leak in the system, as you are smelling the antifreeze - seems to me like the antifreeze is not reaching the core, have you mistakenly plumbed the intake/out take the wrong way round?, this would cause the windows to fog up as the heat is being taken away fro the core rather than being taken into the heater core
No in car heating,blowers working fine but it wont produce heat. Its a 51 plate grand cherokee Thanks
If it won't produce heat then you have an issue with your heater core. The heater core could be bypassed, in which case no hot coolant will get to it to produce heat inside the cabin. The heater core could be stopped up with dirt/debris, in which case the heater core can't radiate heat to produce heat in the cabin. The ducting in the dash could not be allowing the hot air to flow to the vents - therefore no heat in the cabin. I'd start with the heater core and check to see if it is bypassed. This generally happens on older vehicles because the parts can be harder to find.
2answers
My heater radiator is busted can i us ac heatre radiator for heat
The heater radiator (heater core) is what supplies the heat inside the cabin. The A/C core (evaporator) only cools the air, will not heat it.
2answers
Heater core problems no heat changed thermostat still no heat any ideas
try flushing cooling system could be a blocked heater core.if flushing doesnt work remove and replace heatercore.
1helpful
2answers
No heat in my dakota. flushed heater core and replaced therm with a reg one.
check for poor flow to heater core-change heater hoses -check for lime build up at intake connector or worn out water pump -if you only put water through core try using CLRlime cleaner in core-get two 6in pieces or heater hose hook them to core and pour it in and leave for 15 mins then wash out with water hose
Will you still have heat if the heater core is bad?
Depends on whats "bad" If the core is leaking, you will have heat, but will also have a leak! If core is plugged with gunk, the more **** in there, the less heat! Why do you think the core is bad?
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
