Question about Apple iPod nano
I have the Ipod vintage 1051 model, I love my IPOD. for some reason it will not charge up anymore. I have all my music on here and I like to see if I can get it to work again. Can this model be fixed or have a battery change. if so where can I get it fixed
  • Apple Master
  • 7,482 Answers
Hi rainone jami...
You will probably need to replace your battery, they only last for a few years..
I will send you to this website for instructions on how to change your battery and other fixes.
Click on the picture of the ipod and it will take you to where you need to be.
Free answer...Please take time to rate me
http://www.ifixit.com/
Posted on May 24, 2011
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Cant add songs to my iPod or charge it on my laptop!!!
I think you have to install the proper drivers to your computer.
Jul 15, 2009 | Apple iPod nano
Ipod did not connect to pc
hi,
First Turn your PC on. The PC needs to be on to transfer music and charge the iPod shuffle. Then Place the iPod shuffle in the iPod dock connector if you have the newer version. If you're using the original version, then plug it directly into a high-power USB port on your PC. Check the monitor to ensure iTunes has loaded. This means a connection was established.
Apr 25, 2009 | Apple Audio Players & Recorders
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
The new ipod nano
depending on when you got it, i think there is a 30 day warranty but phone the store you purchased it at to make sure.
My 30G 5th Generation pod is totally dead and will not charge even with a new battery
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
