Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
I HAVE A GE FRONT LOAD SUPER CAPACITY PLUS WASHER THAT THE GREY GASKET DOOR SEAL GOT TWISTED AFTER WASHING A LARGE COMFORTER. IS THERE A WAY TO UNTWIST IT? IT DOESNT APPEAR RIPPID BUT I TRIED TO PULL ON IT TO UNTWIST AND IT WONT MOVE
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Posted on Feb 15, 2008
SOURCE: KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Posted on Dec 30, 2006
blueextc3221
  • 15935 Answers
SOURCE: front loading washer leaking water
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
The door gasket is twisted, how do I fix it?
There is a metal retainer with a spring on the outside of the door around the seal remove that and re-form the seal around to door panel and secure with retaining spring. If this doesn't help you will have to replace the seal.
Feb 12, 2012 | Miele Touchtronic W3033 Front Load Washer
I have a GE WCVH 6260 front loading washing machine. It has a massive tear (approx. the bottom third) in the rubber door seal. All the water drained inside the unit, beneath the tub, on down to the floor...
Please join us in this petition to have GE recall this front loading washer! Thanks :)
http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Dec 01, 2010 | GE WCVH6260F Front Load Washer
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Leaking from the bottom from GE super capacity plus washer maching
Take the front off and if it is leaking from where the transmission meets the tub the tub seal is bad. When this happens you have to replace the seal and the transmissson. This page can help http://appliance-repair-it.com/GE-washer-disassembly.html
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
94 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
