Question about GE GFSF2HCY
Our icemaker in model gfsf2hcyc will not dump ice. There is frozen ice in it but it won't dump. Don' know what to do. Thanks for any help!!
fridgetech
  • 473 Answers
SOURCE: Ice maker too slow
Ice makers will only drop cubes about every two hours. There is nothing you can do to speed it up. However, if you have low water pressure to the fridge, then you will have slow production. You need a minimum of 30-40 pounds (constant) of water pressure to the fridge for the ice maker to work properly. Things I typically see causing low pressure are: Self piercing saddle valves on the water line (need drill type), and reverse osmosis systems connected to the fridge. In some rare cases a very old water filter or limed up supply line.
Posted on Jul 15, 2008
Techsim
  • 59 Answers
SOURCE: Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Posted on Nov 03, 2008
  • 1122 Answers
SOURCE: Ice maker won't dump
REMOVE THE FRONT PANEL FROM THE ICE MAKER,SEE IF YOU SEE ANY BROKEN GEARS,ALSO THERE IS A HEATER THAT HEATS UP BEFORE THE DUMP CYCLE TO LET THE ICE DROP OUT,THE BEST TO DO IS REPLACE THE ICEMAKER IF TYOU DON'T FIND ANYTHING,YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE ONE FOR AROUND $50,EASY TO INSTALL-MIKE
Posted on Mar 15, 2009
SOURCE: icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
Posted on May 01, 2009
  • 22 Answers
SOURCE: Icemake rarely dumps ice and when it does they are small cubes
There has to be a restriction in the water supply line from your saddle valve, ( shut off valve on the cold water line ) to the water valve. It can be in the category of, the hole in the water supply line is getting calcium build up or to small of piercing, or it can be a kink in the water line, or even the white fill tube at the icemaker is closing up with ice. 99% sure you will find the problem in one of those areas.
Posted on May 04, 2009
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Whirlpool refrigerator, ice maker stopped working. Line is not crimped or frozen. Thanks for any help! Model ER2CHMXPL00
Is there ice frozen in the icemaker ? If not , pour about 1/2 cup of water into it . If it dumps , then the problem is the water valve . If not , then the icemaker is bad .
Jul 17, 2009 | Refrigerators
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
GE GFSF2HCY Logo
146 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
