Question about Kitchen Ranges
My mach 7 still works with the attatchments, but the brush is not spinning on the main hoover when the brush mode is on, could you tell me weather itis the motor or the belt that turns the main brush! ?and what it is that needs replaceing please!
4 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Posted on Oct 01, 2008
MNfisherman
  • 11896 Answers
SOURCE: we replace the belt on our hoover mach 6 but the
is the motor spinning? If not, it will need to be replaced. If it is, the bearings on the end of the brushes may be stuck
Posted on Jul 07, 2009
SOURCE: Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Posted on Nov 23, 2009
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Brushes don't spin on hoover F7425-900
brush ends probably choked with hair or fibre. use small hook to 'fish' out and pull gently until cleared. re-start and try again
Sep 14, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
We replace the belt on our hoover mach 6 but the brush doesn't spin.
Jul 07, 2009 | Vacuums
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Have a Hoover Model F5887-900 upright carpet cleaner. I am having issues with the attatchments. The brushes will not spin on the handheld attatchment and the solution trickles out. Any...
HI ,
I AM BILL AND I HAVE A SIMILAR PROBLEM. I HAVE FOUND THAT THERE IS A SHIFTER VALVE NEAR THE REAR OF THE MOTOR AREA.
IF YOU LAY THE HANDLE DOWN FLAT YOU CAN SEE WHERE THE VACUUM HOSE ATTACHES TO THE SUCTION MOTOR. CHECK THERE TO SEE IF IT HAS COME APART.
NEXT CHECK THE SHIFTER VALVE AND SPRING MOVE ROTATE 1/3 OF A TURN . WHEN YOU LOWER THE HANDLE THE SHIFTER HAS TO BE IN THE FLOOR MODE FOR THE SUCTION TO THE MAIN FLOOR SCRUBBER AND SPIN THE BRUSHES.
TO USE HAND TOOLS THE HANDLE HAS TO RAISE UP AND LOCK TO OPERATE ANY HAND TOOLS.
A PLASTIC LEVER BREAKS BY A SPRING CALLED THE SHIFTING LEVER. A SHIFTER VALVE LEVER IS THE RIGHT REAR, THE HANDLE DOWN. GOOD LUCK
MY PROBLEM ACTUALLY THE SHIFTER DOOR AND I HAVE A LOT OF SEARCHING TO DO TO FIND THAT.
OH! BY THE WAY THE LEVER PART # IS 90001320 $2.16 + SHIPPING AT SEARS PARTS DIRECT
Apr 29, 2009 | Vacuums
SOLUTION:
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
No suction
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
