Question about Toshiba MK2035GSS 200 GB SATA Hard Drive
Toshiba (MK2035GSS) 200Gb Hard Drive with Vista 64 OS crashed in my laptop. Drive had 2 partitions of equal size (around 97GB each). I attempted to reformat the hard drive to reinstall the operating system, and i receive error messages can not format hard drive. I removed the hard drive and placed it in a removable case to connect to a separate computer (XP Pro) via USB. The drive is recognized (both partitions) but neither can be formatted. I used the Disk Management utility from XP to delete the partitions and create one logical partition. I was successful, now i have a 186.31 GB hard drive (sounds like a lot of bad sectors). I have tried several options to format (quick, NTFS, FAT) to no avail. I wanted to run a check disk, but that application does not start.
  • registrat486 May 27, 2011
    I am waiting for replacement disks to proceed. Can i use Windows 7 disk manager and follow your steps in the meantime?
  • 4,281 Answers
Boot computer with windows disk then delete the partition of that harddrive 5 to 6 times format it then you can install windows on it. Also after booting with windows disk enter in recovery console mode then type below command "chkdsk /r" without "" then press "y' then it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 24, 2011
Toshiba tablet R15-S829 has only c drive .can i do partition in this hard drive. is it accptable for this laptop or not.please help
I think the problem is only that your system crashed. So you can try some data recovery software to recover the wanted data from system partition and then reinstall OS,
I suggest you can use a free data backup software to create a recover disc once you enconter such a problem you can recover your data and system easily.
Freeware AOMEI Data Backuper: http://www.aomeitech.com/aomei-data-backuper.html
Jan 22, 2013 | Tablets & eReaders
I can't find out how to make a recovery disc. Running Vista OS.
If your laptop still has the recovery partition on drive "E" press F8 just before the laptop starts to boot, just as the Toshiba screen dissapears. That will give you the menu option to choose Recover.
Choose recover and follow the prompts.
If the partition is damaged or missing, it cannot be done from the hard drive and the purchase of a Vista system disc will be required.
Jan 15, 2011 | Toshiba Satellite Pro L300 Notebook
How do I setup a dual boot for a PC with Vista and XP? I want XP to start automatically.My laptop is a Toshiba Satellite L355-S7915 that had Vista Home Basic preinstalled.
The first thing you need to do is repartition the hard drive. This will effectively erase the drive because partitions run below the OS level.
You create two partitions and then you can load each OS to its own partition. When the box boots you choose the OS you want to start and thats it...I think if you put the preferred OS in the first partition it will load that one by default.
You need both OS disks to do this so make sure your factory Vista disk works.
Mar 07, 2010 | Computers & Internet
My Laptop Acer 4736_14" has 250 GB HDD with Vista OS has 2 partition; 126, 120. I tried to do it in 4 partition, but it can't be as I hope. Anybody help me, please? Thanks. Sidik Mohamad from Bondowos
How do you want it? it will be around 60, 60, 60 ,60 then. and you may need to install vista again into the laptop.
how did you want it?
you can use the vista setup disk to partition the drive into 4 parts will be around 60 each.
Jun 02, 2009 | Acer Computers & Internet
Hard drive crashed
Since the laptop is no longer even listed on the Toshiba site, you probably need a 2.5" IDE hard drive. You should be able to take it in to any reputable computer/electronics shop and they can tell you positively if it is an IDE device or not (I'd put money that it is). You should be able to use anything up to about 200GB. Anything bigger than that is dicey based on the age of the laptop (the built-in controller may not support drives larger than 200GB). And your recovery disk should not have a problem with using the larger drive although you may need to partition it yourself before running the restore disk since some of them hard-coded the partition information (which would give you a 30GB partition and the rest unused space which you could then use for a second partition with a separate drive letter than the rest of the drive)..
May 29, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
XP NOT INSTALING
well dont boot through vista as it thinks ur downgrading and the micro$oft never thought of that!!
good news just put in your disk boot through your bois and presto it will work!
May 24, 2009 | Toshiba Satellite A205-S5880 Notebook...
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba MK2035GSS 200 GB SATA Hard Drive Logo
267 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
