Error code sc306 - Office Equipment & Supplies
  • 2 more comments
  • natspts May 24, 2011
    ricoh aficio spc410 thanks
    ricoh aficio sp410 printer please asap
    i have a ricoh aficio spc410 color printer that comes up with error code sc306
    unplugged opened front cover took out the unit with the rollers and reset didnt work
  • 4,323 Answers
Hi
Error code SC306 is a charge roller home position error which means that you have to unplug the unit and take the fuser out and then reseat it. If the error returns then its better to get the unit serviced as the corona wire might need cleaning/replacement. Hope this helps...please post back for further assistance.
Daniel
Posted on May 24, 2011
  • Daniel Scott
    Daniel Scott May 24, 2011
    Alright then try cleaning the corona wire, if that wont work then it needs service
  • 6,993 Answers
Hello, welcome to Fixya!
What is the make and model of the printer with this error code. I need more details please.
Bye for now.
Ricoh SP C420DN error code SC306?
Remove the drum unit and clean the ID sencer
Jul 18, 2017 | Ricoh Office Equipment & Supplies
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
I am after an operating manual for a Lumina handheld steam cleaner model SC 306. Thank you
i have lumina steamer model sc306 with out a manual and i can not find where i put the water
Sep 16, 2010 | Vacuums
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 250
Turn the machine off and turn it back on. Usually the code is reset.
Possible charge corona wire error.
Does
Jun 19, 2008 | Ricoh Aficio 250 Copier
Copies & Faxes come out solid black
Sounds like a charge problem, check the clutch that moves the charge roller to contact the drum. The clutch is on the back of the machine. Brad
Aug 17, 2007 | Ricoh Aficio 250 Copier
k24674
jasbo
jasbo
