Myfaxjet 525 shows system error 026 - Office Equipment & Supplies
Rz 200. How do I clear error code R-16-525?
Code: A16-525 Code A16-525 Description Waiting for the master to be removed.
Jul 27, 2015 | Office Equipment & Supplies
Casio TE2200 Error Code 026
You have set that item to be linked to a condiment/ prep PLU which means you set the wrong digit during tax linking. go back and turn the condiment/ prep PLU feature off
Jan 02, 2012 | Casio Parts Cash Register PC Desktop
When trying to install driver get error " DVD Asus
I found Asus driver in the site portal.I also guess that if your PC is an OEM and you just replace the DVD.Also is a good idea to update the firmware.Here is the LINK.(http://support.asus.com/download/download.aspx?SLanguage=en-us).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 27, 2010 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Shift key isn't working properly it is backspace how do i fix this problem
this has been a problem with my "internet navigator logitech keyboard" and when i run the "#keyhistory" script i get these results after hitting
the following keys :
L L RightShift L L CapsLock L L
VK SC Type Up/Dn Elapsed Key Window
4C 026 d 0.47 L
4C 026 u 0.16 L
4C 026 d 2.89 L
4C 026 u 0.17 L
A1 136 d 2.19 RShift
A6 16A a d 0.02 Browser_Back
A1 136 u 0.16 RShift
A6 16A a u 0.00 Browser_Back
4C 026 d 0.80 L
4C 026 u 0.13 L
4C 026 d 2.52 L
4C 026 u 0.14 L
14 03A d 6.05 Caps Lock
AA 165 a d 0.02 Browser_Search
14 03A u 0.19 Caps Lock
AA 165 a u 0.00 Browser_Search
4C 026 d 4.80 L
4C 026 u 0.14 L
4C 026 d 0.11 L
4C 026 u 0.14 L
and as you can see I have two problems with this. One problem is that when i am in an internet browser and i hit shift it acts as Backspace/Back and when i am renaming a folder and i hit shift to use caps it also acts as Back. The other problem is similar with the Caps Lock key, whenever i am in an internet browser and i hit Capslock, the Search window appears and the Capslock function gets activated as well.
I was trying to Remap these two keys but i wasn't successful in doing so,
for the shift key i tried remaping 00_6A and E0_6A to another key and i also tried remapping 00_36 to another key and neither of these two helped.
and for Caps lock i tried remapping E0_65 to another key and it didn't work. I also tried turning off both the shif key and the CapsLook key and their that only turned off their original function but it didn't turn off the backspace or the search functions.
Aug 16, 2010 | Computers & Internet
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Can I update jornada 525 to poquet pc 2002 ?
Unfortunately, the Jornada 525 cannot be upgraded to Pocket PC 2002. The Pocket PC 2002 operating system requires a handheld with a StrongARM processor. The Jornada 525 has a Hitachi SH-3 processor.
Sep 12, 2005 | HP Jornada 525 Pocket PC
191 people viewed this question
jasbo
jasbo
