Question about Goldstar Heating & Cooling
I have a goldstar GP100CE 10,000 btu portable air conditioner, but the part that goes into the window was lost, how or where can i purchase a new one
3 Suggested Answers
  • 306 Answers
SOURCE: bought goldstar portable air conditioner model
search for Goldstar on internet. They may have manuals available free download.
Posted on Aug 22, 2009
SOURCE: My portable air conditioner is posting a E4 on the
My air conditioner is reading E3, it is a portable Goldstar.
Posted on Aug 12, 2010
My questain is can you oil or grease the fan motor, it squeels when its running but other than that ot works fine. its a goldstar wg1005r 10,000 BTU unit?
Usually not on these types of units. If it is squealing, it will eventually seize. You could try spraying some wd-40 on the shaft when the motor is running and then turning it off and letting the wd soak for a while. Usually when wd is sprayed on a motor with bad bearings, it will loosen all the gunk up and make the motor louder than before, but I have had kill the squeal a few times. This is an at your own risk type fix as it could make the problem worse. Best option is to buy a new motor or unit. Sometimes the motor will cost a few dollars less than a brand new unit.
Aug 14, 2011 | Goldstar LG L1004R Window Air Conditioner
What are the dimensions of the vertical window slider kit that comes with the NEWAIR AC-10000E 10,000 BTU PORTABLE Air Conditioner and does it extend to at least 60 inches in height. If not, where do I...
Just build on out of wood and paint it. It will have better insulation than those cheap sliders that get sun beaten and let insects in. Build one out of wood and caulk the edges it will look better and work better.
Jul 01, 2011 | Heating & Cooling
Bought goldstar portable air conditioner model #gp100ce.did not get manul with how can i get one ..tanks
Aug 20, 2009 | Heating & Cooling
It's a brand new Air conditioner, shuts off after about 3-5 minutes of being on then it restarts and continues this cycle. What should I do? Delonghi penguino 10,000 btu
Sounds like it is either low on Freon (factory defect) or the thermostat needs adjustment or is bad. This unit is "short-cycling". There is always a delay between shutoff and restart in A/C systems. This allows the pressures to equalize in the system so that the compressor does not try to pump liquid Freon (doesn't work and almost always fatal for the compressor). If it is this new, return it for replacement. I am assuming that it is a portable or window unit.
Jul 16, 2009 | DeLonghi PACT100P Portable Air Conditioner
Unit doesn't turn on at all. Used to work and just quit
pls check power supply then check the unit switch (selector)
Apr 22, 2009 | Goldstar M1004R 10 000 Btu Window Air...
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
434 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
