Question about Roomba Robotic Floor Bagless Vacuum
My Roomba leaves the docking station, goes about 18 inches and then only turns in circles, first one way and then the other.
  • 823 Answers
The normal action would be to leave the docking station, go towards the center of the room and then start making circles while get larger and larger until the whole room has been done. Then it should go the opposite direction and then the room is finished.
I could not tell by your question, if you were talking about the normal function or if it was just going in circles in the same space - right and then left and shutting down after that.
If it is turning a few circles right and then left, and then the light that the dirt compartment comes in indicating its full - when it is not full - then the sensors are dirty and need to be cleaned. I have this same problem with mine. I have the roomba red. The first few times it did this (turned circles right and then left and then the full light came on) I took it apart and cleaned the filter, then removed any debris that became stuck around the wheels (like hair or string). Then I wiped it down with a wet towel and dried it and that seemed to do the trick. It ran for another six months or so before it began doing the same thing again. After that point the cleaning did not work anymore and I had to buy new filters to get it to work right again.
Try cleaning it out as indicated above and replacing the filter with a brand new one. If that does not work, contact the manufacturer for repair.
Posted on May 24, 2011
I have roomba 880 stationed in open w/nothing blocking view (virtual walls, lighthouse, doors, etc) but it will not go back to docking station even when I press docking and its only 6 feet away.
it seems as if the robotic cleaner is having a problem sensing where it is or failing to notice where its charging station is try cleaning any optical/IR sensors and it maybe able to see once again where its charging dock is
Jan 06, 2017 | Roomba Vacuums
No power to docking station, no lights
check the warranty period and if still under warranty , take it back for a warranty check
Sep 18, 2016 | iRobot Roomba 880 Vacuum Cleaning Robot
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
560 moves away from dock appears lost
hey gsaban
does it sing 9 beep when it stops ?
if it does, you are facing a known issue of bumper sensor fail.
See this page and other 9 beep threads on FixYa
have fun
Avi
Mar 12, 2010 | iRobot Roomba 560 Robotic Vacuum
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Roomba Scheduler will not dock
Clean the contact on the robot and it will dock.
Nov 16, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Oct 29, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
Top Roomba Vacuums Experts
noel
noel
Lonnie Arks
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
