Question about Kenmore Elite HE4 Electric Dryer
Wrinkled closes I have a Kenmore Elite dryer about 2 years old and all the closes come out of the dryer wrinkled. Any idea what this be caused by? Thanks John
  • 594 Answers
Make sure your washer is spinning the water completley out of the clothes. winkles are caused by moister and if there is a lot of moister in the dryer than it will winkle.
Posted on Aug 15, 2008
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Comes out wrinkled and the wrinkle guard does not work. I have tried every setting.
You may have either a bad control board or the wrinkle guard sensors are failing. Either way you want to get a tech out to look at them. It is not something the average home owner should tackle. The wrinkle sensors are 2 metal pads that measure the moisture level. If they are shorted it will bypass the extra heating needed.
Sadly Kenmore of today is not the same as it was 30 years ago. its all the same now. Whirlpool, Kenmore(elite or otherwise) and maytag. That said, once the sensors of control board are repaired, you will be in good shape.
Jan 10, 2018 | Washing Machines
Clothes come out bunched together and wrinkled
Make sure that you take them out very soon after they are dry. Leaving them to sit in the dryer will cause them to bunch together and be wrinkled
May 08, 2012 | Maytag Dryers
Clothes come out super wrinkled?
Just purchased a Cabrio washer/dryer.....biggest mistake I have made in a long time. The clothes come out so wrinkled that you cannot get the wrinkles out wihtout ironing EVERYTHING. These machines are going back ASAP!!!!! I don't care if they are rated #2...they are horrible!
Aug 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Everything comes out wrinkled
Check and see if your "cood down cycle" is working on your unit. If the clothes are cooled down while they are being tumbled, you have a fighting chance of folding them without them taking on permanent wrinkles. The clothes should only be lukewarm when they come out of the machine. (Dryer softener clothes might help some too.)
Nov 25, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
