Question about Bose (321GS) System
Bose system is not getting power, wont turn on. checked all cords and connections they all seem ok.
    Sergeant:
    Novelist:
  • 159 Answers
Check the back of your receiver for a fuse or a circuit breaker. All of the radios I have include a fuse on the back of the receiver portion of the set-up ... usually it is a small round thing, and it should have a label. if there was some sort of surge in your power, the fuse might have blown, and your system would not be getting power. If the fuse is blown, replace it and you should be good ... if not (and you don't have much experience with fixing electronics, a repair shop is probably going to be your next best bet.
Posted on May 24, 2011
Bose power cord for subwoofer
This could be one of three problems:
1) The on-off switch may be going bad.
2) There may be a cold solder connection breaking loose where the power cable attaches to the circuit board.
3. The plug part of the power cable could be faulty. The wires intermittently separate from the connection in the plug.
May 01, 2014 | Bose Audio Players & Recorders
My Bose radio stopped working, no sound no lights AWRCC1
Hello
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Feb 26, 2012 | Bose Wave radio/CD remote control -...
I cannot get multi CD changer to play CD's. Single CD in main unit is OK but no track info etc appears on screen. Also cannot eject cd's in myulti changer.
This seems to be a failure of the micro controller of the unit as it fails to identify as well as display the functions.
You will need to check he connecting cord , check the connectors and the inner voltage to the circuits.
Oct 11, 2010 | Bose Wave music system Multi-CD Changer...
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
I have a bose Lifestyle Series II System which i have enjoyed for years. My son recently tried to hook his I-Pod to it. now i cannot get it to work. Any ideas?
Hi.
The system may have gone on protect mode after detecting a problem.
Try disconnecting the power cord from both subwoofer/amp (Acoustimass), and from main control unit.
While the two units are disconnected, check the control cable from main unit to subvoofer, and check all the speakers connections.
Leave system disconnected for about fifteen minutes, then connect back first control cable, then power to Acoustimass (keep it off) and finally, power to control unit. Turn everything on and see if the system is starting.
If the system is still not starting, then there is an internal fault. In that case call Bose at the number listed on the owners manual.
Regards.
Dec 20, 2009 | Bose Audio Players & Recorders
Bose 321 Power Problem
try to check your ac cord may there's a loose contact between transforner outlet and ac cord of your system
Jul 11, 2009 | Bose (321GS) System
The bose av321 disk door wont open
Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center
Mar 28, 2009 | Bose 3 2 1 GSX System
Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Dec 14, 2008 | Bose Lifestyle 48 System
Will not power up
Your have to open the system removing the six screws on the bottom. Once the cover is off you might want to remove the am/fm connetion to give your self more room. You just unplug it from the board by gently pulling on the white connecting plastic and not the wire. Pull the am/fm board toward the front a bit and lift up. You shold see three shinny metal wires per say. and the one you want to check is the one that looks like it's connecting straight into the display screen. Notice two seem to connect towards the front. You want the one that is straight forward. This was the connection that had come undone on my system and was causing the no power up just the "BOSE 3-2-1" message.
If you need further advise on this procedure e-mail me at
tonyandne4ever@yahoo.com
May 02, 2008 | Bose 3 2 1 GSX System
Bose (321GS) System Logo
178 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
