Question about Home
My electric shower triton t80xr keeps tripping the electric every time i turn it on?
4 Suggested Answers
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
SOURCE: my new triton shower keeps dripping when switched off
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
Why is my triton shower tripping electric shower casing feels hot(on top) too
According to me, you should contact to a professional that really helps you to get rid of this major problem. A professional can easily identify the problem regarding the triton shower.
Apr 17, 2012 | Home
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
My new triton shower keeps dripping when switched off
Jul 27, 2010 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Dec 09, 2008 | Home
MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it...
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Jul 11, 2008 | Heating & Cooling
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
111 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
