Question about Whirlpool Heating & Cooling
What is the age and eer of model acm102xlo - Whirlpool Heating & Cooling
Tip
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers. Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models. Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system. Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period. SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings. The higher efficiency your product, the lower your long-term energy costs will be. Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place. Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost. Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations. If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
on Dec 14, 2009 | Heating & Cooling
I have centrex Air Cond. Model CTAR60GW.Does it meet the EER Rating above 2.9?
Centrex should be able to confirm the EER if you inquire.
Dec 04, 2014 | Heating & Cooling
Eer 1 led4 on outside board? flashing
What does your documentation or wiring schematic refer to on EER1?
Oct 26, 2013 | Heating & Cooling
How many BTU is Model#580.74085 580.74124
8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
Looking for Watts and EER rating.
try ruud.com tech support or google . Tom
Jun 17, 2009 | Ruud UBHC Air Conditioner
How can we caculate the energy needed by an air conditioner?
It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
Example 35000 btus / 2500 watts = 14 EER
If you know the capacity,btus and EER you can calculate the watts, capacity / EER
Example 35000 btus / 14 EER = 2500 watts.
EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Trying to get information before buying a/c and furnace{central}
No, the highest seer, eer is 10.2 in this brand and that includes all catagories of units they make. I believe they are made by ICP, which make Carrier.
Mar 31, 2009 | Heating & Cooling
Eer 2 message on bose 6 cd player on 2001 pathfinder
you may need bose qualified serviceman to erase the error,you may need a software from bose.
Aug 20, 2006 | Bose Wave music system Multi-CD Changer...
Heating & Cooling Logo
101 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
