SOURCE: I have a 5 year
Hi.
The 4 is not an error code, it is telling that the machine is stuck in part 4. The number changes because different cycles perform same action at different times.
The problem can be given by defective pad or defective control module, but first the machine must be tested.
Behind the toe panel there is is a technical sheet in a plastic envelope. In the technical sheet there are procedures to do Manual function test and Field Service test. Such tests will show the real error code.
Once you find the error code the machine must be repaired. Instructions for repair are in the service manual uploaded here : Click here to start download from MediaFire...
If that does not work, proceed from here (same manual).
Regards.
Ginko
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
