Question about Ricoh Aficio 2022 All-In-One Laser Printer
Paper Curling When making multiple sets of 10 copies or more, the sheets curl excessively and eventually impede the path at the output tray. This causes the exiting sheets to completely curl and accumulate out of sequence in the output tray until it is a total mess. I must make fewer copy sets at a time to prevent this from happening. I appreciate any suggestions.
  • Ricoh Master
  • 2,794 Answers
Your fuser roller temperature may be set too high or if the paper has been sitting for quite some time, you may have moisture built up in the copiter. Usually a service technician can adjust the temperature for you.
Posted on Aug 15, 2008
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Mar 04, 2015 | Canon Ir 3300 Black & White Copier
Standard top bin full remove all paper from bin
there are four black plastic finger type actuators protruding from the exit rollers ( in the catch tray) these help push the paper down after exit from printer - in some cases where damp paper is common the curl generated by the fuser heat is enough to trip these \'Fingers\' into the position where the printer thinks the output tray is full to capacity
do you ntoice when the paper leaves the machine if there is any curling in the paper if this is the case open a new ream of fresh paper and try again
also the output tray full sensor is probably covered in dust/paper debris- removing the top cover will reveal the position of the sensor connected to the actuator arms clean and dust this to cure error ( assuming theres no damp paper)
Dec 11, 2013 | HP LaserJet P3005 Printer
Samsung SCX-3405 FW paper curling at output tray
Paper curling, wrinkling, at bottom of page is definitely caused by high humidity. When weather returns to dryer atmosphere, printer returns to normal state. I live in Sydney, and we get days of continuous rain sometimes in Summer. Humidity is very high. The paper absorbs moisture from the air and is easily deformed by the rollers in the printer.
The solution is to dry the paper and reduce the humidity. After a day or so at 50% humidity, the paper returns to normal and will print correctly.
............ Rex Swensen
Oct 22, 2013 | Samsung SCX 3405FW
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Paper curling from excessive heat.
Paper get curled from excessive dampness in paper. The heat from a copy machine is always the same.
Try fresh paper from a new packet. Do not store paper in Humid areas. Paper not being used for a long time, remove from copy machine and store in it's own packet..
Jul 10, 2008 | Canon DHD860 Copier
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Brother HL_5280SW Clack and pages curling
When paper is damp and runs threw the fuser in machine paper dries out and curls, try fresh paper, see this link about paper. Try a fresh sealed ream of quality paper
I dont have this model in Australia but it looks the same as the HL 5270 and there is bullitin released on these to eliminate paper curl, they upgraded the fuser and exit guide to fix this problem, yours is 2 months old so is covered by warranty, contact brother in your country to have it fixed.
Dec 01, 2007 | Office Equipment & Supplies
Ricoh Aficio 2022 All-In-One Laser Printer Logo
503 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
