Question about Texas Instruments TI-5045 SVC Calculator
Where to buy replacement ribbons for T15045SV?
How do I change the ribbon in a Remington sperry rand typewriter?
I was a typewriter tech for seven years. To see if your ribbon needs replace gently pinch it with your finger you should get some ink on them, if not, replace ribbon. Generally speaking, step one if your not sure how to change the ribbon take a picture before you thing , this will give you a chance to get it back together. New ribbon install/ 1. Look at the ribbon, with the hood up,type, and watch to see which spool is paying and which spool is taking up. 2. With your finger turn the take up spool until the ribbon is all on one reel. 3. Note how the ribbon sits in a guide on both right and left spools ( take a picture) 4. The tuff part,the ribbon is laced thought the "hammer block" where the type-heads go to strike the ribbon. (Take a picture) either you lift and lower and lift to " unthread" the ribbon or the other way around, it's not rocket science just note every move you make take pictures. If you get stuck or need further info send back info and pictures and we will go from there. Tip, when typewriters where replaced buy computers many typewriter service company were in the beginning phases of the copier revolution. Many type techs began working on both, you may find help from a long establish local copier company. Good luck, Bret
Dec 26, 2014 | Office Equipment & Supplies
Where can i buy cheap grosgrain ribbon?
What kind of ribbon you want,you can buy grosgrain ribbon and satin ribbon from Yama Ribbon online store:www.yamaribbon.com where i usually orderd.
you can buy grosgrain ribbon:http://www.yamaribbon.com/grosgrain-ribbon.html
satin ribbon:http://www.yamaribbon.com/double-face-satin-ribbon-new.html
christmas ribbon:http://www.yamaribbon.com/christmas-ribbon.html
Sep 26, 2013 | NIB Wholesale Lot Of 6**puffy Plush Flower...
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
I'm trying to replace a Nintendo DS Lite ribbon cable to the top screen. I've heard that you have to replace the entire top screen. Is it possible that you can buy another ribbon cable instead of another...
Naa got to get a top screen they come with the ribbon cable no way around it they are cheap have a look on ebay u can get them for abt $10 delivered
Mar 21, 2010 | Nintendo DS Lite Console
Gossip watches with changeable ribbon straps
good day,
hope this link below will solve your problem.
watches
Jun 24, 2009 | gossip Rectangle Case Leather Strap Watch
Ribbon cable
You will have to buy a broken player with a good ribbon cable to get it replace - if you are still in warranty, call 1-800-SAMSUNG
Mar 18, 2008 | Samsung YP-K3 MP3 Player
Blank screen
there is problem with ribbon of ur phone, ribbon is that parts which connects ur slider part of phone to the lower part of ur phone. ribbon might be damaged. take it technician for replacing it with new one, once it will get replaced u will be able to see ur screen working.
Jan 13, 2008 | Samsung T809 Cellular Phone
Ribbon Cable LCD
yes you can still do that but i think it would be best for you to take the phone to a professional mobile service center and have them replace it for you.
Sep 03, 2007 | Samsung SGH-d807 Cellular Phone
Texas Instruments TI-5045 SVC Calculator Logo
63 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
