Question about IBM ThinkPad T40 2373 Notebook
My IBM think 40 locks down if moved, even the slightest movement lock it down, some time all sorts of video corruption on the screen.. Somethime to start up laptop I would have to press down on the section where the hard drive is located. please assist me.
  • 1 more comment
  • dasina Aug 25, 2008
    I have 2 IBM T40 ThinkPads, both having the same issues. Certainly seems like a loose connection. If I hold the laptop with 2 hands grasping the lower lefthand corner just after powering up, it will start up normally but don't bump it or move it or it will go out. I have opened up both and checked keyboard connections, mouse touch pad connections and hard drive connection. All are good. Next step, it must be some other loose connection on the mother board or in the area of the lower lefthand corner of the laptop. I was hoping to find a solution without breaking them down any further but it looks like I may have no other choice.
  • funlovin420
    funlovin420 Apr 08, 2012
    I have the same problem with my t43 did anyone find the problem or a fix.
  • funlovin420
    Mine did the same up until the point where it quit working unless you press the spot where the hard drive plugs into the motherboard in between your fingers like vice grips and it has become useless.Has anyone found a solution to this problem?
    Genius:
  • 2,028 Answers
This is going to be a connection that has worked loose. You will need to check all connections to the motherboard. Start with the hard drive.
Posted on Aug 20, 2008
Unnecessary movement in the drum when the machine is operating
Start with adjusting the balance-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 08, 2011 | Tricity Bendix AW1000W Front Load Washer
This is the first time i use its new, i don't know why after one hour starting to be buzzing and moving hardly on the ground it seems that it will explode, i tried to switch it fro 40 to 30 but doesn't...
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Good luck,
John C
Mar 15, 2011 | Washing Machines
After the washer rinses and begins to spin the drum seems to have a lot of movement and it makes a banging sound and the machine will not start to spin
I mostly do answer front load problems but ' out of balance' is a common problem with both!
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Mar 11, 2011 | Kenmore 43052 Front Load Washer
Noisy when in agitation or spin mode
You do not say what sort of noise- motor or banging? I always recommend checking the balance before anything else anyway ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!
Good luck,
John C
Mar 07, 2011 | Maytag Performa PAV3200
Nintendo ds lite keeps shutting off
you probably have a power shortage when you move the screen. the only way to fix this is to open the ds, make sure everything is in the right place, and put it back together. i cant promise this will work, but it should.
Jan 13, 2010 | Nintendo DS Lite Console
It wont turn on, and when it turns on, the slightest movement of the laptop will make the screen black and sometimes, the screen has a glitch, i can't move my pointer anywhere and it just hangs. Please I...
Most likely its the LCD cable from motherboard to the screen. This can get damaged especially in the hinge area and can prevent the laptop from turning on and the other problems you mention. Replacing the LCD cable should solve all your problems.
Sep 12, 2009 | IBM ThinkPad T41 2373 Notebook
Dell Latitude D620 locks up when moved
Is this when the ac adapter is plugged in?? Or on Battery??
Feb 06, 2009 | Dell Latitude D620 Notebook
Locked screen
I found a page with a video, on how to open a padlock - I hope this is what you need, it looks easy.
3325d60.png plz let me know how you go - maybe I know of a safe we colud open...
/Teis
Jan 16, 2009 | IBM ThinkPad T20 2647 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad T40 Problem Booting Up
I have a T41 doing this, and pressing on the big ATI video chip (under the wireless card, under the touchpad) would change the machine's mood from bad to good (or vice versa). There are sites saying motherboard flex is the problem, and the solder balls of the video chip (GPU) are the weak link. There is a service on ebay the repairs the solder balls of ATI GPUs for $50, which I will be trying out. Or check Youtube for how to reflow the solder yourself with a 1500 watt heater and an infrared thermometer.
Aug 11, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
186 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
