Question about Sharp Office Equipment & Supplies
I have a Sharp AR M-165. If I try to do more than 20-30 continuous copies or prints I get a darkening of the top 40mm of the copied page which gets gradually darker and darker the more pages that are copied.
  • 372 Answers
Are u using a compatible toner or branded.this problem might be occurring due to toner .try to change the toner and developer .both at the same time because if u change the toner then the toner in developer module will get mixed with new one and u will have a problem
Posted on May 25, 2011
SOURCE:
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
Nov 14, 2007 | Sharp AR-M455N Copier
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
