Question about Cars & Co Disney Pixar Cars Mcqueen Analog Watch
I bought a watch and we can't get it to work. We think the battery needs to be changed.
    Sergeant:
    Novelist:
  • 159 Answers
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
Posted on May 24, 2011
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Marcelo
Oct 23, 2013 | Seiko Coutura Chronograph Watch
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
How do you change the time on vintage Syroco wall clock?
I bought a Syroco 8 day wall clock wind up with key at an auction it winds but does not make ticking sound and does not work ANY IDEAS?
Jun 13, 2012 | Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
Just recievd watch and does not appear to be working.
hi laura! I think the battery of you police watch have to be replace by a new battery if your didn't know how to change the battery, you had to bring it to watch experts. then you said that you have just received you watch and it is impossible that the battery is discharged that is maybe when the date of the watch had been manufactured, it is working for that the suppliers know that there no problem with the mechanism of the watch.. that' it. thanks..
Jul 06, 2011 | Police 12087JS 04 Wrist Watch for Men
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I have citizen eco-drive skyhawk not under warranty. Two weeks ago everything turned off. Nothing works. Do i change battery is there replaceable battery in these watches? I know when i bought it they...
The watch has a "battery" and claims that it does not need to be replaced but perhaps it needs re-charging. If you go to their web site (click on the link below), there is a full explanation of re-charging requirements :-
http://www.citizenwatch.com/COA/English/rechargeguide.asp
May 23, 2011 | Citizen Eco Drive Skyhawk with Atomic Time...
I have a Technomarine abyss, bought as used and don't know if working. Once open to change battery I found that there's oil also in the bak where is tored battery. Is it normal or the watch is...
Hi. It has silicone oil in it. To tolerate diving to that depth the watch is capable. It is normal, but if the silicone has to be completed if some leaked. Take it to the repair service. Best regards!!!!!!
May 13, 2011 | TechnoMarine Abyss ABS01 Watch
Watch is blank/not charging
The watch started working by itself.
Jan 18, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Cars & Co Disney Pixar Cars Mcqueen Analog Watch Logo
222 people viewed this question
Top Cars & Co Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Cars & Co Watch Expert? Answer questions, earn points and help others
