Question about Bogen Communication BOGEN PCM-TIM PHONE INTERFACE MODULE
I have IP PBX system that is using a Bogen system for overhead paging. The Bogen system consists of one PCMTIM, one PCMCPU and two PCMZPM modules and a Bogen GS250 amplifier. The PBX is using a Linksys PAP2 ATA as a gateway to talk to PCMTIM.The cient uses page all option. That is he calls pager like any other phone extension. If everything works properly he should hear two beeps confirming the connection to the pager then dial "00" for page all zones which activates all the speakers makes the announcements and hangs up. The problem is a call to pager makes the two beeps so it is connecting to the pager but it does not any DTMF signals after that. So it does not recognizes "00" for page all option. It sits there for 14 seconds and give a few busy signals and disconnects. When set the switches in the PCMTIM and connect an analog phone to it. I can make paging annoucements directly from analog phone. The PAP2 interface seems to be working fine. When I connect an analog phone to it. I can call outbound and it works fine. I can use DTMF while I am in this mode with PAP2. I will appreciate any help that I can get. Roger Partovi Varietel Communications 801-889-1414 iraj@varietel.net www.varietelcom.com
2 Suggested Answers
palaboy
  • 5807 Answers
SOURCE: Servicing a Bogen PA system
On your TAMB
( Telephone Acces Module )
• Check if there is Audio going out :
sample :
If there is none check power supply
• If the image above does not look like yours
procedure is the same and post.
Posted on Aug 29, 2010
How do I record greetings in Day, Lunch and Night Modes?
This PBX system are you using? if it is an asterisk based pbx, you will need to do a GotoIf statement in extensions.conf.
GotoIfTime(09:00-18:00,,,?[labeliftrue][:labeliffalse])
If you are using UI based system, you can simply do it in the timegroup and timecondition page.
Sep 15, 2015 | Panasonic KX DT343-B Digital phone - Black
Page not heard from other phones in office
What PBX system are you using? if you are using PBX with UI, try confirm the extension number is in the paging group list.
Aug 05, 2015 | Mitel 5330 IP Phone
How do i fix card obstacle error on Panasonic tde 200
Hello Fra,
Your tech support would be best to address this issue.
Nonetheless I am including 2 links that can help you.
Best of Luck,
JP
Panasonic KXTDE200 PURE IP PBX Manuals
Panasonic KX TDE200 Manuals
May 14, 2015 | Panasonic KX-TDE200 Converged IP-PBX...
How to change viocemail for the 2110
IP Phones do not provide voicemail, that is a function of the PBX it is connected to, either a premise IP PBX or a cloud-based (hosted) PBX. If you are using an Asterisk-based PBX system, the usual way to access the voicemail system is to dial 98 from the phone, however you will need to know the voicemail password.
Jul 07, 2014 | Grandstream GXP2110
Audio distortion bogen tpu100b
This is am Impedance imbalance. Most inputs are looking for 600ohm. You need to use a different input or get a way to change you FXS to something else. What we usually do is buy the cheapest IP phone you can and wire directly to speaker. then simply call phone and it will page
Dec 17, 2013 | Bogen TPU100B TPU100B
Is it possible to configure the phone to open a link if there is no answer from a certain number?
Hi eduardoky,
Interesting question. Thats what today call centers are doing with predictive dialer solution.
But if you dont want to go that much advanced, you can opt for CRM connectors. In general they are called CTI. Computer telephony integration.
For Mitel IP Phone, I dont know what PBX you are using.
Refer : http://www.mitel.com/resources/ap_51009460RA-EN.pdf
The following are general steps.
1. Create CTI account in your PBX.
2. Download a CTI client.
3. Connect CTI client with your PBX and map with your extension.
4. Whenever you get a call a page will open. Opening a link when no answer is depends on CTI client.
With CTI API any one can write CTI apps.
HTH
-Karthik
Sep 24, 2012 | Mitel 5224 IP Phone
How can I install a GXP-2000 IP phone, remote (from another location)? I all ready have another phone connected to the PBX box (local) but I need to have another phone remote
The exact method really depends on your ip-pbx and whether or not you will have a persistent VPN between the remote site and the main site.
If you have the VPN then the most you would have to do different would likely be to manually set the ip settings for the phone.
If not, then you will likely be dealing with a pretty complex implementation that will require in depth work with the PBX, firewall, DNS, and possibly security certificates.
Some IP-PBX units do decent job of shielding you from the gory details but without more info to go on, i.e. details on the PBX type and whether or not you will be using a VPN, this is about as far as we can go at the moment.
If you need more, please post a follow up with additional information and we'll be glad to continue.
Oct 02, 2009 | Grandstream GXP-2000 IP Phone
Nortel 1140E IP Phone, Expansion Module 1100 series not working
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
Bogen Communication BOGEN PCM-TIM PHONE INTERFACE MODULE Logo
143 people viewed this question
Top Bogen Communication Computers & Internet Experts
David Payne
David Payne
Are you a Bogen Communication Computer and Internet Expert? Answer questions, earn points and help others
