Question about Aroma ARC-930 20-Cup Rice Cooker
My rice cooker does not cook the rice. It's only on for about 10-12 minutes - goes to warm but rice is not cooked.
kel1guy2002
  • 3740 Answers
SOURCE: Was using rice cooked for sometime. My cooker is
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Posted on Jan 09, 2010
Testimonial: "Thanks for the tip"
bayyagg
  • 1672 Answers
SOURCE: i have rice cooker i cant cook rice.i am on the
U mean, the rice cooker turns OFF after 5minutes?
Sounds like THERMAL adjustment needed!
Posted on Nov 07, 2010
bayyagg
  • 1672 Answers
SOURCE: I can't find my measuring
Hi, Heres a simple way to cook rice! A cup is good for 2 person( unless they eat a lot of rice ), just put some rice and add water! Level the top of the rice grain, the water level should be in the first line of ur mid finger. Then ur ready to cook!
Hope that helps u out!
Posted on Jun 14, 2011
SOURCE: * Cooker does not heat the rice or get hot. * The
heating element not working
Posted on Jul 04, 2011
  • 3 Answers
SOURCE: The cooker clicks over to "keep warm" before the
You're probably using too much water. Rice cooks primarily while sitting in hot water, not while its boiling. That's why the cooker switches to Keep Warm so quickly. The correct way to cook rice is to pre-soak the rice for about 30 minutes, drain to get rid of the excess starch, combine the rice and cold water and bring the water to a boil and turn off the heat and let it stand for 15-30 minutes. That's why*- rice cookers take 45 minutes or more.
Posted on Sep 11, 2011
Rice cooker manual
Not sure which type of Tefal rice cooker you have received.
You may want to go to the Tefal website and pick the manual for the one that could be your model.
http://www.tefal.com.au/Consumer+service/Use+Instructions/Download+User+Instructions.htm?DdlFamily=%7B0A5A8D23-12DD-457A-98D3-F880930BB33B%7D
Though there is not much to it if you are cooking rice. Take the pot out and wash it as any metal utensil. Put as many cups of rice you want to cook in a separate bowl using the measure that would have come with it. Otherwise take a 150ml measure. Wash it the rice thoroughly with water and drop it into the pot. Fill water to the level of number of the cups you have put in. Wipe the pot dry from outside and place in the cooker jacket. Put lid on. Turn the power on and press the Cook button. Once rice is cooked it will switch to keep warm and leave it there for about 5 minutes before you use the cooked rice.
Aug 21, 2014 | Tefal Kitchen Appliances - Others
Tip
How much Rice and Water go in the Cooker
So you lost the instructions to your rice cooker and now you want to know how much rice and water you need in there…
He is what I have found out with using my cooker to prepare rice.
There is a cup that comes with your rice cooker that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup of rice that you want to end up with... Add as many 2/3 cup fulls of rice as the number of full cups or servings that you want to end up with. See my notes about washing the rice further down in this tip.
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line....
If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
Remeber also, if you have a brown or wild rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
The best feature is that you just have to place the rice and water in the unit, press the button for the type of rice you are using and forget about it itll it goes through the cycle and shuts down, going into the hold warm mode....it is so easy!!
These things are really goof proof, and make great rice very easily...a little bit of experimentation and you will enjoy very much using your rice cooker.
on Jul 27, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
Sep 06, 2011 | Aroma ARC-914 8-Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
I purchased today, when i tried to cook rice, followed directions, cook light only stayed on 10 minutes and warm light automatically turned on. Rice and water were cold. I tried several times and reread...
This a bad unit. You sould return for an exchange. There is thermo strip inside to control cooking time and to change the stage of ON/WARM light when it reaches the calibration point depending on the weight of rice to cook. Now it is not working.
Aug 12, 2009 | Rival RC61 6-Cup Rice Cooker
Rice cooker goes to "keep warm" mode before rice is cooked
bad thermostat . there are no parts made for this model . sorry
Jan 17, 2009 | Tiger JNP-1000 5.5-Cup Rice Cooker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Aroma ARC-930 20-Cup Rice Cooker Logo
98 people viewed this question
Top Aroma Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
