Question about Toshiba Satellite A85-S107 Notebook
Toshiba Satellite Windows XP Keyboard problem
A "^" is inserted to each key strock and makes an undisplayable character or a "hotkey". An external PS2 keyboard with a USB pigtail has the same problem. I removed the keyboard(s) from Device Manager, unplugged USB, reboot and did not see any difference. Windows Live Onecare and Norton Antivirus scan find nothing. Reformated HD, reloaded XP, and updated to FP3 does not make any difference.
Does reload BIOS a possible next step? Or replacing MOBO? Is there any other thing I should try??? Please help.
    Scholar:
  • 65 Answers
First and foremost I would reseat the laptop key board cable/edge connector.
I would replace the MOBO. It is unlikely that it would be the Bios or the Keyboard.
Posted on Sep 05, 2008
Hello. some keys like "6,y.u.w
if it is a laptop keyboard that is not working but you want to use an external keyboard just buy a usb one. Typically if you are running an windows xp or newer, it will just recognized the keyboard and you will be fine.
PS2 is that round plug with 6 pins you would find on older computers.
If you did not want to use an external keyboard and want to try to fix the the internal laptop's keyboard, there are a few things you could try:
1'st, shoot the keys with air duster to see if you can dislodge anything stuck under them.
2'nd, you can pop off the keys and press directly on the contact to see if the button works.
3'd, if that doesn't work you can take off the keyboard and ther will be a part number on the bottom of it. type that into google and you can find a place that sells replacement keyboards.
I did this on a Toshiba satellite and it worked fine, just be sure not to break the keyboard ribbon connector on the motherboard when you remove it.
Sep 15, 2011 | Toshiba Replacement Keyboard
My toshiba satellite m45-s355 seems to be coughing up a weird problem.Whenever i press the shift key these characters - "NB~A" props up and the whole system goes awry.I can figure out that it's a...
like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
Jan 14, 2011 | Toshiba Satellite M45-S355 (PSM40U073001)...
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
Hello! I have Toshiba A300-149 ..... Windos7 operating system .... help me find the vista7 Hot Key ...
Hi
You need to download the software for the laptop from the toshiba website, it will be under software / applications and possibly hotkey or keyboard.
Dec 13, 2009 | Toshiba Satellite 1115-S103 Notebook
Toshiba A305 hotkey
Try re installing your operating system (genuine windows xp or vista suggested)
If the problem still persists contact me at
Deepuunni1985@gmail.com
Jul 10, 2009 | Toshiba Satellite A305-S6863 Laptop
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
I have to hold down keys for 2-3 seconds to type. How to correct?
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
ziraffa@hotmail.com
Dec 15, 2008 | Toshiba Satellite A105 Notebook
Keyboard beep
Isolate the issue first. If your using an external keyboard, remove it and test if you still experience it. If not, then there could be a stuck key on your external keyboard.
If yes, then there could be a stuck key on the laptops keyboard.
If there is a stuck key, try to check the buttons on the KB then contact Toshiba to avail of your warranty for the repair.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A40-S270 Notebook
Driver problem
hi there,
try this link:-
http://kmkm.dk/notebook/Toshiba/34343/Toshiba-Hotkey-Utility-1.00.01SE-Windows-XP.html
Apr 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
FN key not working in Toshiba Satellite
Hey,
Try to install these utilies:
Toshiba Common Module
Toshiba Hotkey Utilities
Toshiba Touch Pad ON/Off Utilitiy
Toshiba Utilities.
... in the same order and reboot between them.
One guy posted it on some Forum.All credits to him :)
Hope it helps.
Dec 03, 2007 | Computers & Internet
Toshiba Satellite A85-S107 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
