Leaking on passengers side - Heating & Cooling
  • 3,361 Answers
If it is leaking outside the car it is OK.
If it is leaking inside on the floor board the drain line is stopped up.
Find the drain tube on the outside and use an air hose to blow air into the tube to clear the blockage.
Posted on May 24, 2011
Gas leaking front passenger side of ford windstar
Have you looked under the hood? (I don't mean to sound like a wise guy.) There are two shiney metal pipes one on the front of the engine and one on the rear as you look at it from the front. They run from right to left on the engine. These are the fuel racks that feed the fuel injectors, (assuming that you have a 3 litre or larger v6 engine). These can concievably rust at the left, (passenger), end and blow gasoline out the passenger side. It is also possible that gas could be leaking anywhere on the engine and roll off the passenger side of the engine or if the fuel line on the driver's side has rusted over a cross member of the frame and possibly roll to the passenger side. Also, there is pretty good pressure on the fuel line when it is running. If there is a rust hole on the right side of the line itself, it could spray to the passenger side, hit something and drip off from there. These are just possibilities. Good luck. Jeff M.
Apr 01, 2014 | Ford Windstar Cars & Trucks
Overheating
Was the coolant old and weak? At ten degrees, a weak coolant could result in freezing and that can cause an engine freeze plug to burst open. Check the side of the engine block for signs of leakage around the freeze plugs. Another possibility is the heater hoses. They run along the passenger side of the engine as well. The last possibility is the heater core. If it leaks you may smell coolant inside the passenger compartment. You MAY get a wet floorboard on the passenger side. Coolant leaking from the core usually will fall into the condensation pan for the A/C and run out of the passenger compartment thru the firewall on the passengers side.
Jan 07, 2014 | 2003 Chevrolet Silverado 1500
Coolant leak
will be the heater core, everyone I have ever seen is on the passenger side.not anything else to do it.fogging windshield,definately.
Oct 18, 2013 | 2000 Ford Expedition
Passenger side coolant leak
I'd have to see it in person to comment. The water pump is on the passenger side of the van.
A mechanic would fill the cooling system then pressure test it for leaks.
Aug 05, 2013 | 1998 Plymouth Voyager
Water leaking on front passenger side floor, 2004 Lincoln
possibly you have a bad window seal on passenger side
glass shop should be able to verify and replace seal for you
Jan 26, 2013 | Lincoln Town Car Cars & Trucks
Lexus gx 470 water leak on passengers side
If you are asking about coolant leaking onto the passenger side floor INNSIDE the car's passenger compartment and NOT under the hood you have a leak in either the heater core or one of it's hoses.
Jul 08, 2012 | 2003 Lexus GX 470
I need to know where the a/c condensation tube is located. A diagram or picture would be great. Leak coming in on passenger side.
i have one in the yard but its late here and its a raging thunderstorm outside so have a look in front of the firewall at the bottom passenger side first
Aug 10, 2010 | 1998 Honda CR-V
Leaking anifreeze from the passenger side of the engine
It is more likely a leaking intake manifold gasket. This is a common problem, they are made of plastic.
May 19, 2009 | 1996 Chevrolet Blazer
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
