Question about GE Ovens
How do I replace the hidden element on a GE Profile JCB968SJ1SS range
  • benoitr1 May 28, 2011
    I have a GE Profile JCB968SJ1SS but this procedure probably applies to the majority of GE Profile ranges with a hidden bake (the hidden element is exactly the same as earlier models). Replacement is done by removing the left side panel of the range.
    - Open oven door and remove the hex screws under the range cooktop, raise and hold in place (or remove) the cooktop. It is not necessary to remove the range door but if you want to see your owner’s manual.
    - Remove screws along top of left side panel.
    - Remove screws from the rear of the side panel.
    - Remove utility drawer at bottom of range and from the inside remove the hidden hex screw on lower left side (accessible through a hole in left leg in my case).
    - The middle and upper parts of the front side panel are held in place by gommets and the whole side panel is removed by lifting it up about an inch (pull the rear of the panel out about an inch to clear the console, grasp the front and rear portion of the side panel, lift up and pull the panel towards you to disengage gommets).
    - The baking element is in the lower part protected by insulation and a heat shield.
    - Disconnect the two wires from the bake element and tuck away, remove left hex screw holding the ground wire and heat shield to frame, remove right hex screw holding heat shield to frame.
    - Lift up heat shield AND insulation as high up as you can and hold in place with tape (no need to remove upper clips holding heat shield). I also suggest taping the sharp lower edge of the heat shield to avoid cutting yourself while working,
    - You will need to flatten and tuck some of the bottom insulation under the bottom panel holding the baking element to easily access the baking element.
    - Remove the left hex screw holding the other end of the ground wire and the bake element to the range frame (it is extremely important when reassembling that the ground and bake element screw tightly to the frame – you may have to use a longer hex screw if the element does not snug in exactly).
    - Remove the right hex screw holding the element retainer to the bake element.
    - Pry out the element retainer from it’s left side using a flat screw driver and slide left (the right side of the retainer is simply inserted in the frame with a small tongue).
    - Remove and replace baking element (you may have to exert some force to do this).
    - Reassemble
3 Suggested Answers
  • 38 Answers
SOURCE: how to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Posted on Nov 22, 2009
livewire874
  • 618 Answers
SOURCE: I need to replace the
Remove right (looking from front) side panel . Lift up insulation near bottom . Remove one screw slide toward back and pull out.
Posted on Nov 17, 2010
GE Profile JT912 keep tripping circuit breaker
see this steps and fix it. God bless you
. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#2-2#ixzz2aSmUeYiW
Jul 29, 2013 | GE Profile JT912 Electric Single Oven
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
Nov 12, 2009 | GE Ovens
How do I change the top heating element on a G.E. Profile double oven JKP54G0P1BG
the heating element should have 2 screws in, when removed pull the element towards you then pull off the 2 wires,replace in reverse order.
Sep 30, 2009 | GE Profile JTP18 Electric Single Oven
I was heating my electric oven when one of the filaments popped and stopped glowing. now the oven won't get hot (enough) and i want to know if i can replace it myself or if i have to wait for my lazy...
You can DIY. The element will be about $40.00. Turn the power off to the range. Unscrew the element and pull it out carefully. Remove the wires. Reverse this order to re-install the new element.
Turn the range back on and bake me a cake.
Sep 22, 2009 | GE Profile JTP56 Electric Double Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Radiant heating elements
Check the element with an OHM meter.
This is not rocket science and an OHM meter can be used for many things. Any good appliance parts place, even Wal-Mart will have a meter which can be set to test AC/DC, OHM's etc. Set the meter on OHM setting and touch the two leads on the meter together, you will see the meter arm move. This is simply a test for continuity. Now take the element out of the Range, touch one lead to one end of the element and the other lead to the other end. If you do not get any reading then there is a break inside the element and must be replaced. If you get any reading at all then the element is good and the eye switch must be replaced.
There are some parts which require knowing how many OHM's but in this case you just need to check for a break inside the element (continuity).
You can check an extension cord this way or set it on the volts setting and check batteries. all kinds of fun.
Dec 17, 2008 | GE Profile JSP47 Electric Single Oven
Only one ring of the double ring element works
You have faulty regulator, or the element is faulty., not sure how you access the inside.
Hope this helps.
Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
458 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
