Question about HP Officejet 6200 All-In-One InkJet Printer
6200 Officejet all in one printer has a door hinge detached. One side is fine but I can't get the other one back on. Hinge isn't broke.
  • 11 Answers
SOURCE: Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Posted on Jun 13, 2010
  • 38 Answers
SOURCE: Broken hinge
CAN YOU SEND THE IMAGE FOR THE BROKEN PART
REGARDS
Posted on Jun 06, 2008
worldvet
  • 859 Answers
SOURCE: HP Laserjet 3390 printer right
Sure, they are available. Take note there are two part numbers for your printer. You should see this on the back of the printer but it should not make a difference in your particular part need.
The exploded diagram for the ADF is here. You can click on an illustrated part to see its price. This seems very affordable to me on my inspection.
This is the page to start from when selecting a part. What I found is that the Keyword and Category search did not produce results. I clicked on the Select A Diagram link and the selected the product for the ADF in the Category drop down list. This results in a parts explosion where each part shown is a clickable link to a part listing including price.
You should be able to select and purchase from there.
The ADF Top Cover was only $14. That seems pretty fair but I suggest you look at the part explosions and you will know more of which part you need and want exactly.
Thanks for using FixYa,
Worldvet
Posted on Dec 10, 2008
  • 72 Answers
SOURCE: In transporting our OfficeJet 6310 a hinge broke
I would suggest you to get this replaced from Authorised Service Provider
Posted on Aug 17, 2009
Puppet03
  • 172 Answers
SOURCE: Hinge for the Cartridge Door will not latch. Seems
good old duck tape ;) or go to a print repair shop and see if they have and parts for you.Ink shops sometimes do there own repairs too so try there
Posted on Oct 24, 2009
Testimonial: "Thanks I did not know the Ink shops could do repair. "
Access door unhinged
If it's not broken, there are plastic tabs that fit into holes.
Dec 10, 2012 | HP Officejet 6200 All-In-One InkJet...
Hp 6310 repair hinge
Generally the hinge will fall into a groove when lifted up. If it will not close you can generally lift the lid a bit higher and dislodge the hinge from these grooves and it should close.
Oct 19, 2011 | HP Officejet 6310 All-In-One InkJet...
The hinges on the cartridge access door broke and I can't figure out how they worked before they broke as I would like to just set the top back down and have it mesh so it lays flat and the open door...
When this happened to my Officejet 6400, I noticed that by putting weight on the hinge area, the printer would work. I have made a makeshift clip out of wire hanger so that there is enough pressure on the hinge side of the printer to keep the printer working. You may have to take the clips off to change the cartridge but we can re set the clips. Good luck !! Jyotiprakash
Sep 06, 2011 | HP Officejet J6400 series
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6200 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
