Question about X2Gen MG19VT 19" LCD Monitor
My monitor speakers are muted and I can not reset.
    Sergeant:
  • 167 Answers
It's on the menu just press it then it will pop out and just navigate to the sound menu then uncheck the mute
Posted on May 24, 2011
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
My advueu monitor has built in speakers which are not working now. do not know what is wrong
First--have the speakers worked before? If so, be sure the speaker wire is plugged into the green hole on the back of the computer and also plugged into the monitor.
Is there a volume control on the monitor? If so, be sure it's turned up.
Are you speakers muted? Check in the sounds icon in the control panel (there could also be a little picture of a speaker in the system tray. Many times people mute the speakers and forget they did it.
Also in the sounds area of the control panel, be sure the volume is turned up.
Oct 06, 2010 | Computers & Internet
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
No volume this monitor was given to me the volume is all the way up on desktop and I cant see where any speakers can be put.
Are you sure the monitor can handle speakers? Maybe it has it's own speakers, maybe it has no speakers at all. You can always plug the speakers into your CPU into the sound card, it is usually the green audio port.
That said, some things that you can trouble shoot.
  1. Make sure that the volume is all the way up on the desktop.
  2. Make sure that the volume control is all the way up in the control panel sound option
  3. Make sure that nothing has been muted, the control panel allows you to selectively mute a single device.
Apr 15, 2010 | Samsung 226BW Monitor
Speakers not working
I haven't seen a monitor that needs drivers for the speakers.
Assuming it has a standard 3.5mm plug for sound input from the PC, have you plugged this in between monitor and PC?
The monitor will have a volume control, make sure it's not muted or turned down too far.
Also check the volume control panel on the PC to make sure it's not muted or turned down.
Apr 06, 2010 | Mag Innovision LT776s 17" LCD Monitor
No audio in monitor internal speakers.
Make sure the cable that goes from the monitor to the computers green audio jack is connected.
Check that the monitors speakers are not muted(see if there is an option to do that by pressing certain buttons on the monitor) ,finally make sure the sound on the computer itself is not muted or too low.
Mar 27, 2009 | Dell Microsoft Windows XP Home Edition
No sound from built in speakers
the built in speakers on the monitor are only speakers, they are not run through the video signal cable and have to be connected separately.
many monitors with speakers provide a stereo cable in the package but dont tell what the cable is for.
If there is a cable provided there will be a small jack on the monitor that connects to audio out on the sound card.
There may also be a stereo plug combined with the video cable, that likewise connects to audio out.
If the hardware is connected, there may be a volume control on the monitor that may be muted.
If the problem is a recent thing for a system that previously had working sound with this monitor, try the mute on the audio settings
Jul 12, 2008 | HP vs15 15"LCD Flat Panel Monitor
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes...
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Mar 13, 2008 | NEC AccuSync LCD223WXM Monitor
No sound from the monitor
Plug the monitor speakers into a source of constant sound (mp3/cd player) and make sure the monitor is not muted and volume is at least half way.
If that works adjust the volume and mute settings on the computer
Mar 08, 2008 | Liquid Video E15LCD1 15"
Speakers in monitor wont work
hi there, 1st check the connection of cable speakers. then check the volume control, switch it mid range setting. then check the hardware device if there is no conflict with any device. try to reset your system once again and if still same problem, you may have a Speaker problem, maybe the connection inside your monitor with the speaker has a loose connection or some electronics part failure. TY
Dec 23, 2007 | HP vs15 15"LCD Flat Panel Monitor
X2Gen MG19VT 19" LCD Monitor Logo
114 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
