Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have a Briggs and Stratton MTD. Part Number: 13AN771G529 The tractor will start and drives well in either forward or reverse position, but when you engage the deck, the track does not propel forward but stays still as if in neutral. I would have to put the tractor in neutral and then in the forward position before the blade engages. This occurs almost every time I disengage the blade and reengage the deck. The unit is also occasionally backfire if I put it in reverse and the deck is engaged. At this point the engine will cut out and then I hear the backfire.
kevin000
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
  • 24 Answers
SOURCE: Drive and blade engagement shutsdown the engine.
Sounds like the seat safety switch.
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
miket756
  • 2702 Answers
SOURCE: My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Posted on Jun 20, 2010
Testimonial: "Thank you for theinformation. I did suspect it may be the Piston Rings but I always thought you would get heavy smoke from the exhaust if the rings were going??"
Tractor seems locked in gear wont go forward or reverse and wont start
push dowm on clutch/brake and let it up releases the brake . has to be pushed down to start though
Jul 13, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 20.5hp briggs and stratton will not go forward or reverse when I let off the clutch it starts to squeal and smokes fronm the drive belt
could be as simple as a worn out belt but look to see if there is a oil leak getting onto the belt
May 04, 2012 | Garden
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Were do you put hydro drive oil in. I have a 700ex
Hello, sorry to be the bearer of bad news, but the trans-axle on this is a sealed unit and oil cannot be added. The only thing you can do is an air purge or replace the trans-axle.
Doing a purge is really easy:
  1. put transmission in the freewheel mode so you can push it, ensuring that it is on a flat surface
  2. start engine and run full throttle
  3. release clutch brake
  4. push the drive pedal or lever to the full forward position for a ten count
  5. push the drive pedal or lever to the full reverse position for a ten count
  6. repeat steps 4 & 5 three times
  7. depress & lock the clutch brake
  8. return the transmission to the normal mode
  9. drive tractor
If this fails to correct the problem you may need to replace the transaxle.
If you find this helpful please vote yes. Thank You!!
May 12, 2011 | Poulan Pro 46Inch 22 HP Yard Tractor with...
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
119 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
