Question about Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive
How do i Disassemble a Toshiba 500 GB Portable external hard drive?
SOURCE: Toshiba USB Portable External Hard Drive
There is no drive letter assigned to it.
Posted on Jun 16, 2008
gpetti2009
  • 92 Answers
SOURCE: reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
Posted on Apr 08, 2009
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 7 Answers
SOURCE: How to format a Toshiba
Just make sure you have any and all data that you want saved moved elsewhere before proceeding.
Posted on May 06, 2011
Toshiba canvio 1 tb is displaying red where it used to be blue when I click Computer and it's drives.
It sounds like the drive could be full? Right click the drive and select properties. It will show you how much of the drive is used up
Apr 19, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
No power signal in my external hard drive
Can you still read data from HD? Test USB port with an another cable and an another HD or some USB equipment you know are OK,
Mar 24, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
CODE 43 WHEN CONNECTED
This is usually because the disc control board in the External drive has failed, Try it in a different portable case.
Sep 14, 2012 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Bent pins on mt toshiba portable hard drive
how damaged are these pins can you send a photo
you might need to straighten the pins you could use point nosed pliers
depending on gaps / spaces between pins pliers might not fit
or use tweezers or 2 fine screwdivers holding one at the center of bend the other at the top to try to straighten
hope it helps
Sep 08, 2012 | Toshiba Canvio 500 GB USB 20 Portable...
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive Logo
1,593 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
