Question about Universal Remote Control RF20 LCD Remote Control
I am trying to get my RF20 remote to learn the Zone 2 buttons of my Denon AVR 791 receiver. However, when I try to do this it does not work. I am Trying to use the "Auto" button for the Audio reciever as the Zone selector. Also, to switch to Zone on the Denon remote you have to switch zones, select "Amp button" then select the zone on button. How can I program this? Thank you
SOURCE: universal remote control rf20 code for directv hd-dvr
you will have to buy the logtec harmony 520 remote it programs on internet and works great
Posted on Feb 15, 2009
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Posted on Apr 16, 2009
  • 60 Answers
SOURCE: "Select" button doesn't work-Cox universal remote for XBOX 360
Depending on the specific remote, some buttons may not work with all systems. HOWEVER, in many cases the things you thing the "select button" would do, are done by the "play button" instead (IE: That's how I have to select DVD menu options with my remote).
If that is not the case with you, you can try a different programing code.
Posted on Sep 19, 2009
Testimonial: "I tried that it didn't work. And I tried the programming codes that I found online for the exact same problem but a comcast remote instead of cox."
  • 5 Answers
SOURCE: Ihave an Aeros MX850 remote that was programmed
All you need to do is make a small programming change. Go to and click the contact us link and explain the problem. You will get immediate assistance and they program all URC remotes.
Good luck,
Posted on Mar 10, 2010
SOURCE: I am trying to clone a new Universal RF20 remote
I'm having the same problem... I was going to call customer support. I have had (3) of these remotes... I've never had a problem with the programming.
Posted on May 17, 2010
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Denon AVR-4802 multi-zone problem.
I had the same questions and still can't believe there isn't more information on the topic. It's crazy how much marketing Denon devotes to their Multi-Zone features yet offers very little reference materials on the actual set up. I guess most customers don't use the fearture? Here you go:
-The Multi-Zone on the Denon 4802 is analog only. If you are running digital coax or fiber you will have to run a second line that's analog (eg RCA red/white) from the source to the Denon in order for the signal to to make it to the Zone 2 speakers (regardless if it's Pre-Amp out or direct connect to the Zone 2 speakers from the multi/SB speaker outs. Regarding the Harmony question, I had the same problem with my Harmony 880 and wasn't able to find an answer after multiple searches. Luckily I figured it out when I deleted the receiver from the Logitec device list and started over. Connect the remote to your computer, launch the Logitec Harmony Remote Software, click the Devices tab, hit the Add Device, pick the device type & manufacturer from the drop down list, enter "AVR-4802" under Model and finally hit the Next button in the lower right corner of the UI. The next page solves the Harmony Zone 2 control problem. You will see a message "To use your device in additional zones/rooms, click the checkbox...." Make sure Room 2 is checked (mine was not), update the remote and you're done. The Harmony Device menu you will now contain a second receiver icon called "receiver 2." Hit "device" on the Harmony, choose "receiver 2" and you will gain control over Zone 2 including volume.
Jan 21, 2009 | Audio Players & Recorders
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
Sep 12, 2008 | Denon AVR-2807 Receiver
Denon AVR-3801
Is the signal set to "ANALOG" or "DIGITAL"?
Sep 29, 2007 | Denon AVR-3801 Receiver
Universal Remote Control RF20 LCD Remote Control Logo
88 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
