Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Our Maytag Neptune stackable washer MLE2000AYW stops after every cycle. I must manually click the knob to the next cycle for it to continue. I have also noticed that the fabric softener area doesn't drain sometimes. This started happening after the machine was moved and a vent was installed for some plumbing we had done. Not sure if this has anything to do with the problem.
    Scholar:
  • 79 Answers
Hello, can you determine if your machine shutsdown in the rinse cycles? If it does then the cause is probably the water inlet screens are clogged with debris. See Neptune Help FAQ #8 for more help.
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
    I hope this helps you.
Posted on May 26, 2011
My Maytag Neptune stackable model number mle2000ayw wont spin nor will the door lock light go on
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch.
In the stackable it is just behing the door lock.
Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color)
To be safe replacing both the things would solve your issue,
If you need furthur assistance, You can leave me comment, i may help you
RNJ VINOD KUMAR
Sep 22, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag stackable
Hello, Welcome
At this site you will find diagrams and schematics for your solution!
http://www.pcappliancerepair.com/model-display.php
Please remember to leave a rating before you leave
Huum
Dec 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
574 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
