Question about Dell Photo 964 All-In-One InkJet Printer
Paper wont feed and the language is not Engliosh
My Dell AIO 926 printer will not feed the paper through correctly - mostly it goes through crooked and jams. Also I saw the instructions for changing the language on my control panel but its not working. theres a big exclamation point that is lit up by my on button and i keep getting error messages in Turkish? or some other language scrolling across the window in my control panel..this is sooooooooooo frustrating.
  • kar8v Dec 10, 2008
    My printer keeps on taking in the paper all crooked too! I have tried everything, and can't seem to fix it. Sooo frustrating.
Hello
What you have to do is to uninstall the computer remove all the cables relating to the printer from the computer completley.
Re start the computer
Make sure that the printer you are installing is the only one in the control panel with a small black circle and correction tick this indicates set as default.
Install the drivers first before putting any cables in to the computer
after you have installed the drivers and put all the cables in re boot the computer again
and try Printing etc
Good Luck
Ronnie C
Posted on Mar 25, 2009
Don't ever buy a Dell product!!!!!!!!!!!!!!!!
Very bad quality on all merchandise. Then, if you do have a problem tey send you to India!!!
P O' d
Posted on Sep 05, 2008
  • Anonymous Sep 05, 2008
    Mine keeps clicking around the scanner. Scanner is stuck at one end.
The printer keeps printing green can not stop it it a
fell printer
Posted on Aug 15, 2008
SOURCE:
My dell aio 926 wont print it makes the sounds but paper is blank i uninstalled and reinstalled and cleaned cartridges with cloth says there ink for 43 papges help me
Maybe it has not ink for the color you want to print or the printhead is clogged. In this last, you should change the printhead.
Thanks.
Dec 11, 2010 | Dell 926 All-In-One InkJet Printer
I have a dell 926 series printer lost the booklet how do i load the paper
You posting shows a Dell 3100cn printer (laser), but you say it's a 926 (inkjet). If a 3100, pull the bottom paper cassette tray out and load the paper. Make sure the sttigs for the paper are correct, e.g. "Letter". If it's a 926, the paper goes in vertically at the top rear of the printer.
Apr 25, 2010 | Dell 3100cn Laser Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
My printer keeps saying I have a paper jam, but after inspection I cannot find any paper that is jammed. I also put the copy paper in the correct tray, however when I try to do any of the all-in-one...
usually you have to look at the sensors trough were the paper goes (a small pice of plastic that is suposed to move) maybe you have a blocked sensor.
Jun 14, 2009 | Dell 926 All-In-One InkJet Printer
The paper feeds in crooked.
make sure the paper tray guides are snug against the paper
Apr 26, 2009 | Dell 926 All-In-One InkJet Printer
Paper keeps misfeeding in Dell AIO 924
I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if you can't see anything, then take a letter sized piece of poster board and try to run it through, that should clear any foreign debris (such as paper clips or pieces of post-it notes that you may not be able to see) good luck!
Feb 10, 2009 | Dell 924 All-in-One InkJet Printer
Dell Photo 926 AIO "Load Paper" error
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Jan 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
155 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
