My canon iR 1020 has got problem, it is flushing a report on screen system error E000. how can i fix this problem?
    Sergeant:
  • 167 Answers
Try calling canon support if your printer is still covered by warranty before doing anything that void the warranty
Posted on May 24, 2011
Error E000
E000: FIXING UNIT PROBLEM
replace or repair the fuser unit:
The fixing temperature is very low:
• The thermistor has poor contact or an open circuit.
• The fixing heater has an open circuit.
• The thermal switch has an open circuit.
Jun 17, 2015 | Canon Office Equipment & Supplies
How can i solve the problem of System error E100 in a Canon iR 1020 photocopier?
You should have a PDF Owner's manual on the software install disk. Troubleshooting section should say what the error is and what to do to fix. Or try this:
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR1020
Apr 02, 2015 | Canon Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
54 people viewed this question
jasbo
jasbo
