Question about Black & Decker String Trimmer Cordless 12" 18V
B&D string trimmer- The motor is failing to engage the spool. Sometimes it works and sometimes it dosen't. It is battery powered,18volt. thanks, Mike Brogan
    Champion:
  • 313 Answers
If its electrical then the terminal in the motor is loose.if it is mechanical the problem is the spindle assy.
Posted on Aug 16, 2008
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Trimmer line is spinning but slowly, like it has lost power.
Sounds like just what you said "it's lost power" Are you sure the battery is fully charged? Try another battery if you have one. There is no clutch to slip on this type trimmer. It's got to be either the battery is not putting out enough to turn the motor or the motor itself is bad.
Aug 23, 2014 | Black & Decker 18volt Cordless Trimmer 18v...
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
My trimmer only runs about 5 minutes on a fully charged battery, It seems to be overheating. If I let it cool off it will run again, but only for a short time. sometimes grass gets caught around the...
You sure the battery is fully charged. A bad battery will run a bit and then stop providing enough power. Then if you wait it will have "rested" and work another tad. Then rest again.
Almost sure that your battery is bogus.
Sep 22, 2017 | Ryobi 18v P2002 String Trimmer P2102...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
String wont advance from spool
sometimes thows automatically spool go bad
afterwhile.get a new one
Jul 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Step by Step spool filling on my NEW Black & Decker GH700
Check the bottom of the spool. See the pattern that looks like a circular saw blade. Ensure that the raised edges, do not have any broken/missing sections. Also, check that the pivot lever in the cap, moves freely and engages the space between the same, saw-blade-like edges in the spool correctly. If there are broken/missing sections of the spool, replace the spool with a good one.
Apr 29, 2009 | Black & Decker String Trimmer Cordless 12"...
NST2018 motor housing repair
pull the black sleeve/cover towards you.sometime its easy but sometimes its hard.
Aug 09, 2008 | Black & Decker String Trimmer Cordless 12"...
Trimmer won't run - B&D CST2000
could be loose connection in the motor due to vibration.
Jul 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
69 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
