Question about HP Computers & Internet
Have a error show up as HP image zone-error states X the program has encountered an unexpected error.: object reference not set to on instant of an object
  • 185 Answers
This error is caused when i tried to bind data in grid view in visual studio 2005. the procedure which i followed are as follows, first i have selected choose data sourse in the grid view task and then i selected new data source. then in the data source configuration wizard i have selected database and moved further. then i have clicked the new connection button and entered all the details and clicked test connection, i get the message 'test connection succeeded' after that when i click ok in the add connection page i get the error 'Object reference not set to an instance of an object error'.
Posted on Aug 15, 2008
As soon as i start the computer I get the message HP Image Zone- Error the program has encountered an unexpected erroe.: Object refrence not set to an instance of an object.
YOUR CAMERA MAY NOT BE CONNECTED? IF IT IS CONNECTED, THAN CLICK ON START, TYPE IN HP IMAGE ZONE, CLICK ON THAT PROGRAM GO TO PROPERTIES AND UPDATE YOUR SOFTWARE.
YOU MAY HAVE TO UN-INSTALL YOUR SOFTWARE FOR HP IMAGE ZONE...ONLY IF YOU HAVE THE DISK...THEN RE-INTSTALL AGAIN? WHEN UN-INSTALLING YOU WILL NEED TO UN-INSTALL ALL FILES SO SAVE YOUR PIC'S ELSEWHERE ON YOUR COMPUTER BEFORE UN-INSTALLING!
IF SO...MAKE SURE YOU SAVE YOUR PIC'S IN YOUR DOCUMENTS OR ON YOUR DESKTOP IN A ZIP FILE, SO NOT TOO LOSE THEM.
PLEASE MAKE SURE YOUR CAMERA IS NOT HOOKED UP TO YOU COMPUTER WHILE INSTALLING SOFTWARE FOR YOU HP IMAGE ZONE!
SOFTWARE HAS TO BE INSTALLED FIRST!
THEN SHUT DOWN YOUR COMPUTER, HOOK YOUR CAMERA UP TO YOUR COMPUTER, TURN COMPUTER BACK ON...IF THE COMPUTER DOESN'T RECOGNIZE OR DETECT THE HARDWARE FOR THE CAMERA, THEN YOU'LL HAVE TO GO INTO YOUR COMPUTER AT THE START BUTTON AND GO TO INSTALL HARDWARE!
IF YOU HAVE THE DISK, YOU CAN ALSO TRY JUST PUTTING IT IN YOUR HARD-DRIVE AND IT WILL GIVE YOU OPTIONS OF UPDATING ETC,.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Compaq Presario 5000 PC Desktop
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
The following dialogue keeps popping up on my computer and I can't get rid of it no matter what I do: "HP Image Zone - The program has encountered an unexpected error: Object reference not set to an...
Hello
HP image zone is a photogrph application that sounds like it has become corrupt.
You can try to reinstall it and the error message should go away.
Here is a link to H P.Just find your software and download and install it.
http://welcome.hp.com/country/us/en/support.html
If you do not want to install it try going to control panel,add remove programs and find the software in the list and click uninstall.
If this doesnt work.type regedit in your search bar,click on regedit then scroll down to hkeylocalmachine software,open up the list and look for any h p software listed there and delete.
Warning! before you delete any thing in regedit be positive its the correct software your deleting.
I would be more apt to reinstall the software for the program.
Dec 02, 2010 | Computers & Internet
Error message I get when I open my HP Image Zone Plus
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-26821-1&lc=en&dlc=en&cc=us〈=en&os=228&product=431078
You can download HP Image Zone Plus from HPs website listed above
Might I also suggest downloading Googles Picasa works almost the same and doesn't have so many problems
Oct 07, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
Hp officejet 7310 all-in-one software will not install
  1. Solution one: Make sure the hardware is functioning correctly(try to make a copy)
  2. Solution two: Restart both the All-in-One and the computer
    3. Solution three: Check if the correct scanning device is selected as default under HP Software
    4. Solution four: Download and run the Scan Diagnostic utility(FROM HP.COM)
    5. Solution five : Check that the Digital Imaging Monitor is running
    6. Solution five :Try scanning without HP Imaging software
    7.Solution six :Try scanning without HP Imaging software
Jan 26, 2009 | HP PSC 1410v All-in-One Printer
Image Zone
This can probably be fixed by reinstall the software again. Sounds like something went a little strange the first time it was installed. Just insert the disk again, and pretend like it's the first time installing. It should fix your problem. If not, comment back and we'll try some other things.
Steven
Sep 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
I am getting an error message when opening hp image zone express
Wow, it sounds like Image Zone Express has some serious problems. If you reinstall that program (be careful to have a backup of your image store so far!) you might get a better result.
Were you somehow uncertain that the problem item so far was Image Zone Express and not HP Compaq DC5700 Microtower - Free Flat Panel etc.? Better questions make for usable answers.
Jun 23, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Scanning to WP 9
Hi this should be problem with Software u need to Install "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch" for Scan Quality
please use below link for patch .select correct OS & download "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch"
if this information is useful for u please Rate me......
May 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Image zone plus
tell me camera model & if it having memory stick or not if ur havinf it then u can transfer it from memory stick also
Oct 15, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
