Question about Cycling
Lost left pedal where can i get a replacement?
    Brigadier General:
  • 8,546 Answers
No one sells one pedal. And we don't see any details about your bike in the post.
Bicycle shops, hardware stores, some Big Box stores sell them, but only a bicycle shop will get it right the first time and install it correctly.
Posted on May 24, 2011
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
May 26, 2014 | Cycling
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
Trying to replace the pedal, cannot get the existing pedal off of the bike. It is the left pedal shaft that will not come off. The bike is a Schwinn 220 excersise bike
Are you sure that you're turning it correctly? The left pedal on almost all properly designed bike pedals turns counter-clockwise to remove, the opposite direction to normal.it's to ensure that normal forward pedalling action cannot unscrew the pedal.
Jul 18, 2011 | Cycling
I've got some roughness in the left pedal spindle. I noticed the left pedal squeaking yesterday. I put some lube on it after my ride which seems to have done the trick with the squeak. Pedals about 7...
bobby, if it was feeling rough or if it squeaked as well, but oil made it seem better (or not, does not matter), the pedal bearing is defective and should be replaced by the maker if the pedal is under warranty. I presume they'd replace the pair, though it is unlikely for both pedals to be bad, you'd want a cosmetic match, natch.
Apr 24, 2011 | Time iClic Ti Carbon
My son left the dome light on all night. Replaced the battery. The truck starts but will not stay running. Ran perfect when I parked it.
The computer has lost its memory for idle control possibly.Try this, crank the truck and shut is off.Do this as many as 20 times , each time try to leave it running for 2 or 3 seconds so you can see if it will idle on its own.Do this till it relearns base idle.
Feb 27, 2011 | 1999 GMC Suburban
Pedals are hard to turn as bike had set up for 20 years.
The pedal ball bearings are probably rusted and/or seized. Try putting oil into the side of the pedal, or replace the pedals. The right one has a right hand thread the left has a left hand thread.
Nov 09, 2009 | Cycling
Brakes
The brakes just need to be bled properly which take 2 people or a bleeding pump,Please tell me how you are bleeding the brakes.
May 17, 2009 | 1998 Audi A4
Cycling Logo
32 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
