Question about Eizo Computers & Internet
My name is Yasir Siddiqui from Pakistan, and sorry my English is very poor so plz dont mind it, my monitor setting is not good my means the screen setting is full and my display of screen is not leveled it is looking very bad shape, when i use the setting but there is no enough memory to set the screen in good shape, regards Yasir Siddiqui
  • 45 Answers
SOURCE: Monitor Menu Settings
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Posted on Oct 01, 2008
techie2050
  • 126 Answers
SOURCE: aoc monitor set up
re install the drivers for garphic card or video card of your computer
thankyou for using fixya and dont forget to rate the solution
have a nice day
Posted on Feb 19, 2009
skotkolr
  • 558 Answers
SOURCE: My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Posted on Apr 05, 2009
  • 460 Answers
SOURCE: i want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Posted on Nov 12, 2009
  • 732 Answers
SOURCE: My Fujitsu Siemens LL3200T display suddenly looked
allan943, As a test, try to swap-in an old known good monitor to your pc to verify pc and graphic's card are ok. Or move LL3200T to a known good pc. If pc is ok, then LL3200T may need warranty work or will need trip to shop for repair of internal power supply. When very strange things start to occur on any lcd screen the first place to investigate would be unit's switch-mode-power-supply!!! This unit should have a 3 year warranty on it. Check with Fujitsu-Siemens to see if they will do a refurb swap-out for you. Please respond with additional comment on what you will or plan to do about this lcd display so all other owners will know what to do. 12fixlouie north of Windy City USA
Posted on Apr 02, 2010
Testimonial: "Many thanks 12fixlouie. I do have a 17" Fujitsu monitor in the loft which I can try somewhen. I'll post the outcome when I've done it. "
Hi this is Yasir from Pakistan..I am using blackberry bold9000...My cell phone does not get charged..neither from computer nor from electricity..i have used disfferent chargers as well but it does not work...
A.A, Yasir. This is Nooh from Pakistan.
Hmm, first things first, try to remove the battery and check the connections, they should be clean. If they are then try to keep it connected with the AC Charger, NOT via PC, over night. And Also try this connect the AC adapter with the Phone, then remove the flap and remove the battery (While the charging pin in), and then put the battery back in, and keep it in the charging mode, over night or 5-6 hours.
If none of these work, then try to replace the battery, to make it sure either it is a battery issue or the Charging unit is burnt.
If you are having any questions, so ask me. I'm here to Help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Jul 31, 2010 | Cell Phones
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Unlocking code for sidekick id
Hi
You will need to purchase the Unlock Code that is unique for your phone in order to be able to use it there. You can email us at sales@cellunlock.net or visit our website.
Feb 25, 2009 | T-Mobile Sidekick ID Cellular Phone
Need country code
my w800i sonyericsson cellphone used in austrilia has network problem coverage in nigeria.i'm in nigeria and i want to use here in nigeria.PLS.it is W800I
Jul 29, 2008 | Sony Ericsson K800i Cellular Phone
Help about driver and softwera
which monitor you are using ...?
you mean you need the graphics driver or the monitor driver itself reply clearly i will get you the links...
and also tell me the model of the monitor if it is monitor driver & motherboard details if it is graphics driver ....
i am always here to assist you ..
reply me soon
Apr 07, 2008 | Mitsubishi Diamond Pro 900U 19" CRT...
I would say the rom is going out .
and may be fixed by re-seating it.
it takes a tool though to get it out without cracking the socket.
it should look like this one on the right
http://www.lcdrepair.us/e193fpc-logic.html
Feb 06, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Screen Resolution problem in vb.net application
hi friend this problem consist still u can't set all controls manually . Means to say first get the resulation of the screen and then programataclly define the location and size for the controls
vinod.shivrain@gmail.com
Dec 06, 2007 | Computers & Internet
Fujitsu Plasma
yes you can connect airial antenna to your tv! what do you mean by wash? or you can clean your monitor with 100% cotton...
Sep 15, 2007 | Televison & Video
Computers & Internet Logo
56 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
